Shivering on the gear stick
08.05.2020 16:42 # 1
ufuk91
Guys, I just realized this problem, I can say that the shift lever is obviously shaking or even shaking, especially in 4th gear, so much. There were people who have experienced this problem before, but I could not reach a clear conclusion, do you have any hearing, hearing, etc.? Or an idea? I don't know how much it costs, I hope it doesn't cause much trouble, but most likely there is a problem in the transmission. "Angry"
08.05.2020 16:42 # 2
EmSul
Is it normal if the gear is flickering with the throttle when the gear is idle?
08.05.2020 16:42 # 3
Barut
I had the same problem as it was due to the left axle. When the axle changed, the problem disappeared. I suggest you look at the axle.
08.05.2020 16:42 # 4
ufuk91
[QUOTE = 206xs] I had the same problem as it was caused by the left axle. When the axle changed, the problem disappeared. There was already a voice in the car, right from the back, tonk tonk. We showed it to the master, the tires on the axle shoe were damaged, finished, something like that. I guess it is necessary to look at the axles. Is there any other idea? He does it at 4 and sometimes at 1.
08.05.2020 16:42 # 5
Barut
look at the motor ears, too, this event is especially in the winter of motor ears, namely the wedges and axles, I found a lot of parts to find the problem. 0 "alt =" Thumbs Up "title =" Thumbs Up "/>
08.05.2020 16:42 # 6
[QUOTE = ufuk91] Guys, I noticed this problem as well, I can say that the gear lever is tremendously flickering in the 4th gear, even if it is shaking, it is so much. There were people who have experienced this problem before, but I could not reach a clear conclusion, do you have any hearing, hearing, etc.? Or an idea? I don't know how much it costs, I hope it doesn't cause much trouble, but most likely there is a problem in the transmission. "Angry" [/ QUOTE]
There is an important point that we need to know in order to clearly explain the source of the problem. You say you're in 4th gear. Is it only in 4th gear, or is it just as fast as you go in 4th gear? So my question is whether your problem is in 4th gear or 50-60 km / h or at what speed you are going in 4th gear. If you try the results at different speeds and write the results here, we can go to the solution step by step. I think your problem is occurring at a certain speed, not in 4th gear.
08.05.2020 16:42 # 7
feline
It is exaggeratedly in the 4th gear in me. I think this is the reason for the gear chock. I have been coming for 2 years, this situation is obviously shaking in 4th gear, but I have never tried to press the gas when it is idle.
08.05.2020 16:42 # 8
ufuk91
[QUOTE = 206xs] look at the ears of the motor, this incident has changed a lot in order to find the problem especially in the winter of the motor ears, namely the wedges and axles, I changed the last motor wedge slightly, but when the main left axle changed, the problem disappeared [/ QUOTE] I had a voice problem, maybe it is the same problem, teacher, let's look at it. Let's see it soon. [QUOTE = koliva] [QUOTE = ufuk91] Guys, I just realized this problem. so. There were people who have experienced this problem before, but I could not reach a clear conclusion, do you have any hearing, hearing, etc.? Or an idea? I don't know how much it costs, I hope it does not cause much trouble, but most likely there is a problem with the gearbox. You say you're in 4th gear. Is it only in 4th gear, or is it just as fast as you go in 4th gear? So my question is whether your problem is in 4th gear or 50-60 km / h or at what speed you are going in 4th gear. If you try the results at different speeds and write the results here, we can go to the solution step by step. I think your problem is occurring at a certain speed, not at 4th gear. [/ QUOTE] Actually yes, I did not do a detailed examination, I may have paid attention to it only because it shook very clearly in 4th gear, but it does not vibrate in other gears either. Let me try 3 and 5 at the same speed then, or try it at different speeds in 4th gear, let me give you clearer information. Thank you all for your help and interest :)
08.05.2020 16:42 # 9
enmerkar
I have the same problem, I even say that when you go on the broken road, it does not tremble when you go (you will see if you can try it) but when you go on the straight road, tremor is felt especially in the 4th gear ... when the car is downhill downhill, sometimes the gear shifts obviously. it does not tremble ... I think it can be made from gearbox chocks or axles .. one of the master I went to said it was one of the wheels, someone said it was bent from the axle, someone said from the ball, someone said from the lower motor ear, someone said from the swing, etc .... I didn't understand it. I have a problem with the master where I am, if you find a solution, I would be glad if you share it and I will do it accordingly ..... enmerkar 2012-04-14 22:57:58
08.05.2020 16:42 # 10
ibrahim YILDIZAK
........... ibrahim YILDIZAK 2012-04-14 22:34:46
08.05.2020 16:42 # 11
ibrahim YILDIZAK
Is it normal if [QUOTE = shumofnsb "emrah"] is shuddering to the gas pressure when the gear is idle, I am wondering this [/ QUOTE]
normal for Gti.
