Shivering and pulling right?
08.05.2020 16:43 # 1
fatih.ctk
I have a winter tire in my 307 right now, I can not go to the expense as it has been 1 week since the winter tires cause problems in use in the summer. thank you in advance
08.05.2020 16:43 # 2
hsnsnl
I do not think the vehicle will want to balance the rod, but if the tires are bad, then it will not be a solution. & nbsp;
08.05.2020 16:43 # 3
impertore
Bumps & nbsp; or if you entered the pits quickly, the ball joint rods may have become loose. & nbsp; I don't understand much, but if you want to see ...: D
08.05.2020 16:43 # 4
cey cey
If the tires are winter, I think it is a pity, do not drive in the summer, get out with those tires, take 4 seasons and make the rot balance correct.
