Shit out the right wheel
08.05.2020 19:47 # 1
Furkan_58_
Easy to everyone, I have 2001 206 I got the undercarriage overhauled the discs, we renewed the pads, but now we have the right ten-wheel pulling out sound, I took the handbrake adjustment, there is corruption in it, he said he will do it, he said it passed, but he did not pass, still there is such a situation.
08.05.2020 19:47 # 2
furkan rims may be caused by steel or black wheels if there are black wheels and wheel covers. Secondly, if there is curvature in the dictation, it may rub against the lining. the pads may not be fully seated by changing them.
08.05.2020 19:47 # 3
Cyrus35
First of all, you say the sound comes from the front right wheel? How did the mechanic attach it to the parking brake, the parking brake is controlling the rear drum or discs? ? I wondered about this situation too :)
Does the problem disappear after a while (When the vehicle gets hot) So if the sound comes from the belt or if the car makes the sound from the belt bearing where it stops, my sound comes from the bearing team, and the sound of the whistling accelerating as it gives gas?
08.05.2020 19:47 # 4
usta307
If my brother is a steel rim, you can also make a rim of the rim, check it out, I overhauled the entire ten layouts.
08.05.2020 19:47 # 5
Gilan
friends, I also get an interesting voice from the right side, I did not get a response, I did not get a response, there was a sound like water sound, then turned into a creak, I did not apply a special spray to the door wicks, did not remove the fender, I could not see anything, I could not figure out what happened
08.05.2020 19:47 # 6
Cyrus35
Sir, it makes more sense for you to remove the wheel hub that makes that gap and have it adjusted again. Shocked God forbid it means the gap is over the wheel bolt Confused
08.05.2020 19:47 # 7
Gilan
[QUOTE = usta307] If my brother is a steel rim, he can also make a rim check.
When I say steel cant, my original rim is not attached later
08.05.2020 19:47 # 8
Furkan_58_
Brother I do not know that the steel rim was dismantled, mounted again, it did not improve again, it even seemed to increase even more.
08.05.2020 19:47 # 9
usta307
Original peugeot rim with plastic rim with blanking rim, the room freezes and makes a sound
08.05.2020 19:47 # 10
Furkan_58_
How do I not understand what is turning around what I have to do to cut the sound
08.05.2020 19:47 # 11
Furkan steel rims must have a plastic rim, sometimes the dismounts do not pay attention while doing the disassembly and assembly processes.
http://urun.n11.com/diger-lastik-jant-ekipmanlari/celik-jant-bilezik-seti-p111648289?cid=604001&gclid=cmatrethxcwcfwoz0wodrvml2w&gclsrc=aw.ds
08.05.2020 19:47 # 12
Furkan_58_
But the sound is cut when the brake is lightly touched, but the exile is what 😐 😐 😕
08.05.2020 19:47 # 13
Dadas-25
Get well soon
Does the sound of scratching sound when you turn the steering wheel while the car is stationary?
08.05.2020 19:47 # 14
Dadas-25
[QUOTE = Gilan]
friends, I also get an interesting voice from the right side, I did not get a response, I did not get a response, there was a sound like water sound, then turned into a creak, I did not apply a special spray to the door wicks, I removed the fender, I could not see anything, I could not solve what happened [/ QUOTE]
Is there a jerk when my brother turns the steering wheel while the vehicle is stationary?
08.05.2020 19:47 # 15
Gilan
There is no sound when stationary, it starts after about a two km journey, my nerves are broken
08.05.2020 19:47 # 16
Dadas-25
do you feel the creak when the steering wheel turns left and right
08.05.2020 19:47 # 17
Gilan
On the straight road, as if I put it in a carboy, I checked all the holes in it, even looking under the car
08.05.2020 19:47 # 18
Dadas-25
When the steering wheel was left right, if there was a squeak, I would look at the table of that side.
08.05.2020 19:47 # 19
Gilan
Tables new rods new good
08.05.2020 19:47 # 20
KILIC
same sound coming from my corsa. 2 weeks ago, the front team changed completely. There is a sheet rim on it, but it does not come all the time.
Page : / 2
