Shift Up Low Speed
08.05.2020 21:15 # 1
samizeldestan
Hello friends. I have 2000 engine automatic 4 AL4 gearbox. The vehicle sometimes shifts up at low revs and acceleration is very low when I hit the throttle. The car goes like a dog when I take the manual and drop 1 gear. Can this car be adjusted for a slightly higher revs upshift? By the way, I usually use the car on LPG.
08.05.2020 21:15 # 2
talip206
It is good for the car to shift up immediately. It provides less burning. Automatic cars are produced for comfort, not performance. Use as much as possible without playing with the gear lever. Otherwise, you will cause big problems in the near future.
Let's come to your question;
The harder you press the car's gas pedal, the later it shifts gear. If you want the gear to change late, press hard on the throttle and do not pull your foot.
talip206 2019-06-12 00:55:59
08.05.2020 21:15 # 3
samizeldestan
Well, I want to ask something, for example, do I have to shift the gear into neutral while waiting in the red light or if D stops, is there no problem?
08.05.2020 21:15 # 4
talip206
You can take N for a long time. But as soon as the light is on, taking D and moving will damage it. It is necessary to switch to D at least 5 seconds before the green burns.
Never take N on the move, just take it while you wait.
