Shift at 2nd gear
08.05.2020 20:59 # 1
Gurhanm
Hello friends
I had my coil installed on my vehicle 3 days ago. Everything is fine, but the gearshift lever jumps at 1.5 rpm and low rpm. He's doing just the 2nd gear too, which wasn't there before. Coils were removed, I think they removed the axle.
Gurhanm 2018-08-13 13:28:36
08.05.2020 20:59 # 2
samet206
As I understand from the inside of the gear lever, I was going to write my full guess, and I saw the answer to the question after you wrote it. but it is important. It may be in a different problem.
samet206 2018-08-13 21:42:04
08.05.2020 20:59 # 3
Gurhanm
Thank you for the answer, brother, now I wonder if the axle is broken with the plug or did not fit properly.
Or are the engine or transmission chocks dismantled?
08.05.2020 20:59 # 4
boruc
Axle problem frequently seen in flattened vehicles.
When the vehicle is bought, the axles do not operate as they should, so they will deteriorate shortly.
In the future, you may experience problems with the gearshift knob, such as the head's shaking / vibrating when accelerating.
08.05.2020 20:59 # 5
Gurhanm
Your friend is in the car too, there is no problem with him, so I bought a coil and even look at the front team problem. Coiller.
