Shall we wear 307 crankcase protection?
08.05.2020 18:32 # 1
sabri_23
mrb friends I'm thinking of wearing 307 me crankcase protection, but I think it will prevent it from getting cold in the hot weather of summer. sabri_23 2014-05-10 08:18:27
08.05.2020 18:32 # 2
Serkan
I have never heard that crankcase protection can prevent the engine from cooling, I think it should be installed.
08.05.2020 18:32 # 3
BG307
It already exists in the 307s.
08.05.2020 18:32 # 4
sabri_23
[QUOTE = BG307] Already in 307s. [/ QUOTE]
If the previous owner may have stung or broken plastic, I said I would appreciate the hair.
08.05.2020 18:32 # 5
herry
Having sheet metal makes it more durable, stretches but does not break. According to plastic, he has a long life. I have not heard of warming, I use it myself.
08.05.2020 18:32 # 6
kuscu38
I removed it from my 306 and it was a little low because rubbing was rubbing. only one of my friends said that he had bought C4, he had it in the car, they made it from sheet metal, it was not nice and nothing but weight. No, you can drive your vehicle in mountain peaks or hollow places.
08.05.2020 18:32 # 7
Alicilik
Some brands use plastic, especially since the engine should fall down in the event of a frontal accident. Otherwise, the engine can push the chest and compress the driver and passenger in case of an accident.
Toyota said, absolutely, definitely do not replace crankcase protection with metal while buying the vehicle.
I bought and assembled it in 206, then it was 60 TL. I gave it to 5-10 screws and mounting. at least I think it will be safe unless I get a very hard blow (stone sitting).
08.05.2020 18:32 # 8
sabri_23
I think the 307s are high both protects and your voice decreases.
08.05.2020 18:32 # 9
herry
[QUOTE = sabri_23] I think 307 high is both protecting and decreasing the sound, do I decrease the sound? [/ QUOTE]
the sound will not decrease, if you want the sound to decrease, you will get the capillary felt.
08.05.2020 18:32 # 10
sabri_23
I just got the maintenance done after the vehicle got built, it sounded as if I put the total quartz 7000 10w 40 oil I wonder why
08.05.2020 18:32 # 11
simirnoffredbull
it is useful must be attached simirnoffredbull 2014-05-10 19:55:51
08.05.2020 18:32 # 12
muhoist
My plastic has been in the vehicle for 2 years, when it was broken, I wore it, I did not see any trouble in the summer.
08.05.2020 18:32 # 13
elsoberano
When I bought it, I did not see a problem where it is not clear where we will encounter a hole or an object that will damage the car.
