Shall I have LPG 306?
08.05.2020 15:09 # 1
Conqueror
Hello friends,
2000 Model 306 PLANTIUM 1.6 I am thinking of having LPG installed on my 80.000 km vehicle. They say it is not compatible with what I heard from the forum and from the outside. I want to make my final decision after discussing with you. Please give me ideas of 306 users.
There is a particular question I am wondering if it is not compatible, why not? Is there a technical explanation? For example, Volkswagen FSI engines do not fit LPG because the injectors are inside the combustion chamber and the fuel injectors burn frequently (this may or may be a different explanation to my knowledge).
Thank you in advance for your help.
08.05.2020 15:09 # 2
cinarxx
I have 1998 306 1.8 automatic gearbox, I am using atiker sequentially, I am very pleased, since the 306s are called the full group, they are different from other vehicles and do not accept errors, so they call lpg ciler incompatible or something. I use it with lpg service and use it comfortably. Although my vehicle is 1.8 and automatic, it has 8.5 lt lpg consumption per 100 km on the long road and it is around 11-12 lt per 100 km in the city.
08.05.2020 15:09 # 3
lpg systems are applied to non-direct injection engines except for some exceptions. The importance of assembly quality lies here.
Do not pass by the master who says 306 lpg does not fit. because it is obvious that the heat does not know :)))))))))
it is very nice. everybody knows that i'm already using. My father also has the same machine as me. We also added a renzo brand that works fine.
08.05.2020 15:09 # 4
[QUOTE = cinarxx] I have a 1998 306 1.8 automatic gearbox, I use it in a row, I am very pleased, 306s are called as full group, they are different than other vehicles and they do not accept errors, so they call lpg ciler incompatible or something, rather than the brand of lpg kit. Install it to a lpg service with reference that has already been installed and use it comfortably. Although my vehicle is 1.8 and automatic, it has 8.5 lt lpg consummations per 100 km on the long road.
I want to make a little correction when they write. Because he should not be wrong.
this full group of pediatric injectors is painful and closed together. this is not about the car, it's about the engine. For example, the 1.8 16v machine on the wall works with a semi-row spray. besides, injector 1 and 4 work together, injector 2 and 3 work together. besides, all 306s are nothing but full group. full group, such as 1.8 8V machine.
08.05.2020 15:09 # 5
THE SAME CAR WAS USED, WE WOULD NOT HAVE A BRC.
08.05.2020 15:09 # 6
I do not know the new 10 and 11 of the brc, but I heard that the previous constraints are not compatible with half-row and full-group engines, always causing problems. I couldn't get the rest of the service from the central service.
but our motors are working smoothly with other scarves ... there are proofs ... Emrah 1.6 8V motor wiper was used without problems. get crazy about that. firstly the scarce full group must be compatible ...
but there is mastery in the press of everything. let that peugeot have a lot of problems in all kinds of scarves in many brands ...
the cecol 2011-03-14 11:36:37
08.05.2020 15:09 # 7
Yusuf Tekoglu
When I See This Title, I Can't Estimate How Frustrated Our Cecoli Brother EmbarrassedEmbarrassed
08.05.2020 15:09 # 8
[QUOTE = Yusuf Tekoglu] When I See This Title, I Can't Estimate How Frustrated Our Cecoli Brother EmbarrassedEmbarrassed [/ QUOTE]
Gülme I got used to relax now Sırıtma
08.05.2020 15:09 # 9
dukenukem82
If you do not have it, there will be no zavoli-lovato-atiker.
08.05.2020 15:09 # 10
[QUOTE = dukenukem82]
yes, the motor in question is also in your vehicle. you are one of the last lpg wearers to this engine. but again I wear LPG on this engine and I know it in the field in the press :)) Here is the brand selection and master factor ...
08.05.2020 15:09 # 11
dukenukem82
knowing this, I went to an ankara representative of zavolin, yes, the engine was full-blown, the master said, no problem, in our system, we had assembled a lot, said pejoya. I swell your head with my questions. I even asked until the km counter. It is a problem for those who have a trip computer :)
08.05.2020 15:09 # 12
[QUOTE = dukenukem82] knowing this, I went to the ankara representative of zavolin, yes, the engine is full-blown, the master said, no problem in our system. I swell your head with my questions. I even asked until the km counter. the problem with those who have the trip computer is god:) [/ QUOTE]
As it is said, there is a newer problem. you have been torn, of course :))
I don't have a gas indicator at all, isn't it comfortable? :))
08.05.2020 15:09 # 13
dejavuer
4 years ago, I had 306 gti installed on my car. Star
08.05.2020 15:09 # 14
sniperElite
First of all, whether my vehicle is a full group or not, it lpg me. It looks at the plus poles coming to the injectors. Feeding is also my sequential system, third and lastly, 4 injectors are fed from one point plus plus one, this is called full group, and the system does not fit it, it doesn't fit in the lpg. be careful that the dealer has 2a engineering service.
08.05.2020 15:09 # 15
[QUOTE = sniperElite] my friend first of all, whether the vehicle is a full group or not, it made me try lpg very much. two injectors are fed from the same plus pole. These are authorized dealers and dealers. Be careful that the dealer has 2a engineering service. If you write google 2a engineering, they have their form, you can ask whatever is stuck there. [/ QUOTE]
oh my teacher don't do it The same as the 1.6 machine in the 306's, there are many in the 206's. After the 2001 model, the 206's are 16v and 110 hp. This 8v 90bg machine is a full group in general. veee you say this engine does not fit lpg this cooooooook wrong. We put on a wall and there are those who use it in the club. I have the same machine, I have 206, my friend is very pleased. He had the same engine as a friend from ankara last, and he got 206 zavoli, which he is glad ...
I think you have fallen into the hands of never knowing top. You are wrong about this ... we have explained clearly what happened above, I think you have not paid attention anyway ...
By the way, you said that 2 + 2 people are in line, which is wrong. It is 2 + 2 half row. it is the same in my machine. Sequential means that each injector sprays according to the firing order. as well as 1-3-4-2 means that it should work respectively. As an example, we can give this engine 1.6 16v machine with TU5JP4 code in 306 and 206.
By the way, you said brc. The 2A engineer center is in the Istanbul paperhouse. me is the nose of my nose. 300 meters above, there is a honey they call center service. When I went there, I do not understand, I do not understand, "" "we do not wear brc to peugeot and cıtroen. Because it is very troublesome. It does not fit. but the situation may be different in the new software of brc. I can't say anything to him ...
08.05.2020 15:09 # 16
cem brother I wrote here because I don't have a separate subject :)) I say I will get LPG on my vehicle. After the last hikes, I couldn't afford the gas money. If you do not approve, the customer of my vehicle dealer is ready. : ((
08.05.2020 15:09 # 17
don't worry. find enough good master ... if you say i do not know i will guide you somewhere nice don't worry. your machine should be full group. I say it should be because there are very few differences. but the engines in common are full groups.
After LPG, you can easily get into your vehicle :))
the cecol 2011-03-14 23:15:20
08.05.2020 15:09 # 18
Did I answer, I wrote to the other side.
I don't know for this tube. If there is someone who knows the job, let's get an offer and finish this job. I don't want to sell a lot of money anymore. If I sell it, I buy diesel feline again :))
08.05.2020 15:09 # 19
[QUOTE = mustafakirli] Did I answer, I wrote to the other side.
If you can come to meet, if you can not meet, let's see on the phone. I will send you a good master ... I am sure you will be satisfied :))
08.05.2020 15:09 # 20
tugrahan
I have a 306 1.8 16 v vehicle (same engine as the cecolinin ki) would be assembled on Tuesday
With the brc my-11 kit, but due to the delay in customs, the kit came at the weekend, so we postponed the installation to the rain due to the busy work pace at the weekend (if something goes wrong)
Let's go to sleep now
This engine works semi-sequentially, it is called semi-seguantal. The injectors send two-by-two fuels, so that the job that knows the group connections must be installed by a skilled master.In addition, the software of the installed kit must have a separate setting called semi-seguantal (in many versions of AEB). If the same working petrol injectors and LPG injectors are synchronized and fine tuning is given every 1000+ revolutions, the vehicle runs stably unless there is a hardware failure.
I decided to brc because the settings I mentioned and more are available in this my-11 kit, and they also guarantee 100000 km warranty for hi-tech segment injectors special for this kit + they change one by one without the difference of the dealer or city (there are many examples of this)
Page : / 2
