Shaking-singing when the vehicle is traveling at high speed |
| 08.05.2020 18:43 | # 1 |
My vehicle: 307 1.6 meizn / LPG automatic SW. My problem: As the vehicle travels on the asphalt on a straight road, from 70 km speed, it shakes as if someone is holding it from the back. While driving, I try to shift to N and it still shakes a little, but not as much as it gets on the throttle. It doesn't matter whether gasoline and LPG are doing the same problem in both. This problem is not available at idle. Starting the vehicle was difficult, but the second starter, even though it took the second starter, now the injector gets better as soon as it gets better after getting the cleaner and trying. The starter is a little delayed for the first time, even 2-3 seconds. normal. Solutions tried: Spark plugs, air filter, engine oil, oil filter changed. Tires became Balance. The rot has been adjusted but there is still a right draw. Left table swing changed. Rot heads have changed. Coil changed, no change. At different times, you tried in road conditions ramp down-up- rain does not matter the dry weather problem continues. When the car is loaded in the gas at the park position, when the load reaches 2500-3000s, it seems like the same thing is happening, the vehicle is moving forward as if it was going to move - the car swings a lot when I pull my foot out of the gas. What do you think could be the problem? |
| 08.05.2020 18:43 | # 2 |
My Prediction: Transmission oil is at the bottom or it's time to change. - the transmission will come down - axle may be a problem - wedges can be a problem - There may be a problem with the fuel pump - There may be a problem with the temperature sensor or other sensors. ... In addition, the replaced parts must be taken originally. If the vehicle is still pulling to the right, tire pressures should also be checked. I recommend nitrogen as the air. |
| 08.05.2020 18:43 | # 3 |
[QUOTE = mertdemiray] Hi, My vehicle: 307 1.6 meizn / LPG automatic SW. My problem: As the vehicle travels on the asphalt on a straight road, from 70 km speed, it shakes as if someone is holding it from the back. While driving, I try to shift to N and it still shakes a little, but not as much as it gets on the throttle. It doesn't matter whether gasoline and LPG are doing the same problem in both. This problem is not available at idle. Starting the vehicle was difficult, but the second starter, even though it took the second starter, now the injector gets better as soon as it gets better after getting the cleaner and trying. The starter is a little delayed for the first time, even 2-3 seconds. normal. Solutions tried: Spark plugs, air filter, engine oil, oil filter changed. Tires became Balance. The rot has been adjusted but there is still a right draw. Left table swing changed. Rot heads have changed. At different times, you tried in road conditions ramp down-up- rain does not matter the dry weather problem continues. When the car is loaded in the gas at the park position, when the load reaches 2500-3000s, it seems like the same thing is happening, the vehicle is moving forward as if it was going to move - the car swings a lot when I pull my foot out of the gas. What do you think could be the problem? [/ QUOTE] Are there any changes in your heat while experiencing these? sounded like a heat sensor malfunction
| 08.05.2020 18:43 | # 4 |
fuel pump may have had the same problem
| 08.05.2020 18:43 | # 5 |
[QUOTE = popeyes] [QUOTE = mertdemiray] Hi, My vehicle: 307 1.6 meizn / LPG automatic SW. My problem: As the vehicle travels on the asphalt on a straight road, from 70 km speed, it shakes as if someone is holding it from the back. While driving, I try to shift to N and it still shakes a little, but not as much as it gets on the throttle. It doesn't matter whether gasoline and LPG are doing the same problem in both. This problem is not available at idle. Starting the vehicle was difficult, but the second starter, even though it took the second starter, now the injector gets better as soon as it gets better after getting the cleaner and trying. The starter is a little delayed for the first time, even 2-3 seconds. normal. Solutions tried: Spark plugs, air filter, engine oil, oil filter changed. Tires became Balance. The rot has been adjusted but there is still a right draw. Left table swing changed. Rot heads have changed. At different times, you tried in road conditions ramp down-up- rain does not matter the dry weather problem continues. When the car is loaded in the gas at the park position, when the load reaches 2500-3000s, it seems like the same thing is happening, the vehicle is moving forward as if it was going to move - the car swings a lot when I pull my foot out of the gas. What do you think could be the problem? [/ QUOTE] Are there any changes in your heat while experiencing these? sounded like a heat sensor malfunction [/ QUOTE] Is it a heat sensor? What is the explanation that makes it like this? The temperature is not changing, by the way. |
| 08.05.2020 18:43 | # 6 |
[QUOTE = eren106] fuel pump could have had the same problem [/ QUOTE] He is doing it in LPG The pump has just changed, I don't think there is a problem in him.
| 08.05.2020 18:43 | # 7 |
[QUOTE = pusut is] My Prediction: Transmission oil is at the bottom or it's time to change. - the transmission will come down - axle may be a problem - wedges can be a problem - There may be a problem with the fuel pump - There may be a problem with the temperature sensor or other sensors. ... In addition, the replaced parts must be taken originally. If the vehicle is still pulling to the right, tire pressures should also be checked. I recommend nitrogen as the air. [/ QUOTE] - Transmission oil just changed, not as much as 3.5 liters. - Gearbox master (Şaşmazda GençMer Şaban Usta) experienced. Akis said the head may have said nothing in the gearbox. Knockback knock etc. neither - When it came to Aks, but does it not work at low speeds if the axle is defective or the shaft is bent? - What do you mean by wedges? - My fuel pump has just changed and LPG grandfather. I don't think it's from him. - What is the reason why the temperature sensor said another friend? Can you explain how the temperature sensor makes such a misfire? By the other sensor, it works normally in the morning. I don't suspect the crank sensor. I don't know if it makes the eccentric sensor. The vehicle goes up to 4000-5000-6000 revolutions. - The problem of pulling the vehicle to the right is that we have moved from the tire to the front and then moved to the right. But after the 70's, the misfire-shaking-cutoff, which is evident, now seems like the vehicle is pulling its millimeter foot from the gas. |
| 08.05.2020 18:43 | # 8 |
FORUM AYAĞA KALK I HAVE A PROLEME HERE GET HAND AND SOLVE YAHU
| 08.05.2020 18:43 | # 9 |
I have the same problem, I couldn't solve it, the fuel pump changed, the spark plug changed, there is nothing in the ignition coil.
| 08.05.2020 18:43 | # 10 |
ahmed206 |
Obviously there is a cycle-related disorder that is not fast-related. It seemed to me that it was related to the LPG brain, but it did it on gasoline. If it is still possible, perhaps an idea may be obtained if the LPG has been completely disabled and tried. At least LPG can be eliminated. |
| 08.05.2020 18:43 | # 11 |
can be map sensor
| 08.05.2020 18:43 | # 12 |
[QUOTE = ahmed206] Obviously there is a cycle related disorder rather than a rapidly related one. It seemed to me that it was related to the LPG brain, but it did it on gasoline. If it is still possible, perhaps an idea may be obtained if the LPG has been completely disabled and tried. At least LPG can be eliminated. [/ QUOTE] It may not be related to the cycle, let's say it is 2 gears, we went up to 2500-3000 cycles. But 4th gear 75-80 revolutions 2000-3000 problems are felt obvious.
| 08.05.2020 18:43 | # 13 |
I decided to replace the car's sensors. I will start with the Crank sensor first. Crankshaft 3-wire Ground, 5V, 8V ignition injectors according to the condition of the crankshaft, etc. so I'm going to start from it. My vehicle does not turn on the malfunction lamp. It also goes where it should go, but when it reaches the 70-80s it kicks. so first I will start this sensor unchanged, maybe I will check the cables and socket before it changes, but just in case I will get 1 because a vital piece may not be found everywhere. Without this, the car does not work at all. Let me start and write the result.
| 08.05.2020 18:43 | # 14 |
Replace LPG injectors and LPG filter
| 08.05.2020 18:43 | # 15 |
[QUOTE = lead38] Replace LPG injectors and LPG filter [/ QUOTE] It is already done. LPG is OK. There is the same problem with gasoline.
| 08.05.2020 18:43 | # 16 |
I did not read anything because I changed LPG injectors. The same similar events happened in my vehicle, I changed the LPG injectors and filter. |
| 08.05.2020 18:43 | # 17 |
Well let's say that. How do you explain that it is not at low speed or speed. Doesn't the vehicle do this when the vehicle is not walking where it stops, if it is from injectors? Or wouldn't it be in low gears and revs? The vehicle starts completely at the 4th gear after the speed of 75-80 km. I also tried this. The same problem occurs when the light ramp reaches that speed (75 km) around 1800-2000 rpm, without raising the rpm without overloading the engine. I do not have to do it because it is in the evening. I know an expert rot balancer. |
| 08.05.2020 18:43 | # 18 |
How to Shake it to the ground, it does not necessarily go on the way. It was good for me to idle gas while stopping in the car, but when I was in 3rd gear, it started to gas off shaking. injectors are expensive parts, but each part has a lifetime. I think you find a good LPG master, explain the problem well or you will spend a lot of money by changing the parts as soon as possible |
| 08.05.2020 18:43 | # 19 |
[QUOTE = lead38] How to Shake It Stops, it does not necessarily go on the way. It was good to have gas idling when I was standing in the car, but it started to shake the gas when I was going to go in 3rd gear. The problem has changed. Of course injectors are expensive parts, but each part has a lifetime. I think you find a good LPG master, explain the problem well or you will spend a lot of money by changing the parts as soon as possible [/ QUOTE] My master is doing the problem in gasoline. If there is no crank sensor replacement tomorrow, I will remove the axle and have it checked |
| 08.05.2020 18:43 | # 20 |
Okay, shaking is about the fuel system. He looked at the master and said there was nothing. Shaking has nothing to do with axle.
