Shaking problem in 1.6 hdi
08.05.2020 19:58 # 1
Hyper1
Hello
When I press and release the gas while working in my car, the car starts to shake when it drops to normal in the relay, when I stop and stop in the busy traffic, the swing stops after a few seconds at the same time, there was a black smoke throw, I sent it to the master, he said that he had injectors to both problems and made repairs, the smoke problem was solved but the problem of shaking continues, I took it again two days left, the repairer did not pass the injector no one at this time, he said that the socket needs to be changed, I changed it to the electrician, it still continues,
At different times I changed the right motor and luck time ear,
Anybody faced with such a problem, I could not see in the form,
By the way, I just joined you :)
08.05.2020 19:58 # 2
lazianke
A similar problem happened in my fabia tdi car, when it came to replacing the diesel filter, a few master injector malfunctions, injector replacement, cleaning, etc., there was an unsatisfactory socket malfunction.
08.05.2020 19:58 # 3
GokhaN
If there is a noise such as squealing in the engine, if the injector is shaken, you may feel it is less than the transmission and the engine ears.
08.05.2020 19:58 # 4
Hyper1
At a suitable moment I will go to the electrician and have his checks, sensor socket etc. If there is a solution, I will write again
08.05.2020 19:58 # 5
Hyper1
Maybe we put on the side industry while changing the engine ear, the transmission ear was original, I will look at it in turn, this shape is annoying :))
