Shaking Problem
08.05.2020 19:18 # 1
themurat54
I am facing a new problem :)
When I start the car, I usually wait for it to warm up a bit and the car shakes slightly, which does not work steadily, which bothers me.
Does it from the ignition coil? Could it be related to idling engine?
I would appreciate if you can help if you know or come to you.
08.05.2020 19:18 # 2
riderzist
[QUOTE = themurat54] I am facing a new problem :)
I would appreciate if you can help if you know or come to know. [/ QUOTE]
If I think there is a lpg in the vehicle (an atiker?) it is most likely an atiker. I also guess the problem is in lpg injectors.
You can make a trial like this (I did the result: LPG shortage; take the gas before stopping the car, wait for 5 10 seconds, then stop it (when the engine is cold). Let it pass for a while. When you look at the coils when you look at the first ignition system, the masters can understand the spark plugs.
Get well soon..
riderzist 2015-06-06 03:56:39
08.05.2020 19:18 # 3
peogeot 307
I will look at the same distress weekend.
08.05.2020 19:18 # 4
sezar206
my coil spark plug is new but still doing it. When it goes to the tube, it works more smoothly. I did not understand that the idling engine is around 200 to 250 lira 1.6s. The vehicle's 1.4 se is around 50 lira. It does it when the engine gets warm, but less. A master, your idle engine is malfunctioning, but I don't know I will show you two more masters. Do you smell gasoline when it first runs?
08.05.2020 19:18 # 5
themurat54
I would be glad if you let me know. I think I changed the ignition coil, it was pretty good. I don't know if it's psychological anymore. I feel less is normal, I have to try it in another vehicle
08.05.2020 19:18 # 6
themurat54
I smell gasoline, but the smell from the exhaust seems like themurat54 2015-06-12 00:27:55
08.05.2020 19:18 # 7
berk2309
the smell of gasoline throws a normal amount in the first time in the morning but makes the shake more than the bob.
08.05.2020 19:18 # 8
sezar206
My coil has just changed sister original boin buli new but still doing. LPG is doing a little more in gasoline. When the engine warms up, the lpg also gets better, but it is also slicked in the same way. It looks like gasoline.
