Shaking at idle on 206 1.4 gasoline
08.05.2020 20:24 # 1
memo32
Hello friends
We have a 1.4 automatic vehicle, the vehicle is quite good in the tube, only when the engine is cold, when I start the vehicle, the vehicle runs fine and the engine wakes up until the engine temperature is over 35 degrees, and the engine stops heating.
No problem when you switch to LPG
Sometimes I drive it on gasoline, we don't have a problem when the engine is hot.
I am waiting for your help, friends Wink
memo32 2017-06-12 10:34:29
08.05.2020 20:24 # 2
so you have this problem in gasoline. I think my teacher say use it in 100-150 km gasoline. problems of this type are generally oxygen sensor - map sensor - gas pump - filter - coil and spark plugs
