Shake p0300 error on gasoline
08.05.2020 21:23 # 1
x571
it only gives extreme jolts and p0300 error on gasoline. If I run the car directly with LPG, there is no problem, but if it starts with gasoline in the first run, there is a problem. After a while, it also works properly on gasoline.
When the ignition is on, I hear the pump noise. When working on gasoline is improved, it is fixed at 130. But again it is a bit jerky, but it does not burn fault. During failure, the exhaust does not explode, only the traction falls and there is a very strong jerk back and forth, the vehicle does not go to 3. I replaced the coil with delphi last year.
There is a leak from the rocker gasket, can these spark plugs pass through and cause trouble. Can the injector also be a problem. Can I control the injectors?
x571 2019-12-02 18:36:02
08.05.2020 21:23 # 2
There may be a problem with one or more of them, brother.
Defective spark plug or wires Defective coil (package) Defective oxygen sensors Defective fuel injector Burnt exhaust valve Defective catalytic converter (s) Stuck / clogged / leaking EGR valve / passages Defective camshaft position sensor Defective computer
08.05.2020 21:23 # 3
x571
soner brother now where to start the control, how would you do
08.05.2020 21:23 # 4
start by removing and cleaning the injectors brother. There are many videos on youtube, even the apparatus is sold, cleaning the lining spray. When was the last time the gasoline filter changed, which controlled the gas pump.
08.05.2020 21:23 # 5
x571
[QUOTE = sonerkyl] start by removing and cleaning the injectors brother. There are many videos on youtube, even the apparatus is sold, cleaning the lining spray. and when was the last time the gasoline filter changed to control the gas pump. [/ QUOTE]
When the contact is opened for the pump, they said it is sound if it sounds, but if there is another control, I will try if you tell me. filter was 20 thousand km alternate. it's time to care but does it do it?
08.05.2020 21:23 # 6
omerb
Is your vehicle automatic gear?
08.05.2020 21:23 # 7
[QUOTE = x571]
No sound from the pump does not mean it works correctly, brother. you do pressure test and check sound listening mastery. you can just replace the engine. I recommend the bosh brand.
