Shake in automatic gear
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Brands
08.05.2020 19:03 # 1
okan0665
Hello friends. My dad's 98 model fully automatic Daewoo Lanos vehicle has various problems and I would like to get your opinion. The first of the problems is that when driving on the straight road, the sound of the `` chum '' coming from below, as if occasionally hitting the bottom of the vehicle. This sound has no effect on driving, the car does not shake, performance does not decrease, the car continues on its way as if nothing had happened. The second is the jerk in the vehicle with the gear in the D position. The vehicle has the form of wanting to go but not going, it shakes you like a cradle on the seat you sit. The jerk decreases in the N or P position, but still does not cut off completely. It is not possible for us to change the vehicle at this stage, we cannot give up automatic gear, so we want to have it repaired and ridden without any major expense. I would be glad if those with suggestions write. Thanks in advance ..
08.05.2020 19:03 # 2
dream
When was the last time you changed the gearbox oil?
08.05.2020 19:03 # 3
okan0665
I know that it changed with the timing last July.
08.05.2020 19:03 # 4
dream
[QUOTE = okan0665] I know that it changed with the timing last July. [/ QUOTE]
Then
1) make sure the transmission oil is correct
2) Have the electronic valves in the gearbox checked.
08.05.2020 19:03 # 5
okan0665
Okay, the first job on the weekend is to get them checked. I declare the result that it will benefit everyone. Thank you for your interest.
08.05.2020 19:03 # 6
okan0665
The problem was caused by the lpg setting :) While it was gone, it was also maintained periodically, we had some cost :)
