Sezgin from Ankara
08.05.2020 21:22 # 1
sezginsasmaz
I am Sezgin from Ankara.
I am among you with the Peugeot 407 1.6 HDI Executive.
08.05.2020 21:22 # 2
omerb
Hello intuition, welcome to us. Have a good vehicle. 407 is a good tool. I wish you years without accidents and problems.
08.05.2020 21:22 # 3
sezginsasmaz
Tskler. Although I have some minor deficiencies, it is a really great tool. May Allah not show accident to our sentence.
08.05.2020 21:22 # 4
omerb
full model.?
My friend has full house. So beautiful. I like Peugeot's diesel engines. Does your lap go of the sex?
08.05.2020 21:22 # 5
sezginsasmaz
I want to ask something when I think of it.
407 1.6 HDI Executive model ...
- Headlight sensor (Does it burn itself when it gets dark)
-Bluetooth
Is there. So can we connect the phone.
Can friends with knowledge clarify the subject?
Thanks in advance.
not sezginsas 2019-11-25 21:57:45
08.05.2020 21:22 # 6
sezginsasmaz
Just no sunroof. Whatever you look for, thank God.
08.05.2020 21:22 # 7
ocaliptus
Hello, There is everything you say but unfortunately Bluetooth has no place, so I got Navimex Multimedia installed.
08.05.2020 21:22 # 8
whisky
There is a headlight sensor. if it is not on, it may be off. good luck again your vehicle
08.05.2020 21:22 # 9
welcome to us I wish you to use your vehicle without any accident, good luck.
08.05.2020 21:22 # 10
sezginsasmaz
[QUOTE = whiskey] headlight sensor is present. if it is not on, it may be off. good luck again your vehicle
Thank you so much. You will laugh at me, but where do I activate the closed headlight sensor.
08.05.2020 21:22 # 11
sezginsasmaz
[QUOTE = sonerkyl] welcome to join us. I wish you could use your vehicle without any accident. [/ QUOTE]
We found it nice, Mr. Moderator. Nobody should be in an accident that I am a victim of. It was always the car in my mind that 407 and God gave it But I'm suffering a lot of strangeness. I will complete those shortcomings thanks to your words. Fortunately, you exist.
08.05.2020 21:22 # 12
whisky
do not mention it. When I press and hold the button on the end of the headlight on / off arm, it had to be adjusted as it shows on / off the screen. we may have forgotten the adjustment when using it like this: D
08.05.2020 21:22 # 13
sezginsasmaz
[QUOTE = whiskey] not at. When I press and hold the button on the end of the headlight on / off arm, it had to be adjusted as it shows on / off the screen. we may have forgotten the adjustment when using it like this: D
I'll try and let you know. Let's see if you have forgotten: D but if you say we may have forgotten, the information you provided, your approach to those who seek help, is excellent. Thanks to you, I started to love my car more. TongueTongue
08.05.2020 21:22 # 14
sezginsasmaz
CryCry
Good evening guys.
There was no headlight sensor event I was talking about today. I did what you said. I long pressed the button on the signal handle, no clicks. I said let me see the menu. I found the place but when I want to confirm it, the screen returns to the top. It made me crazy. Isn't there a solution for this, God's sake? I want help from you
08.05.2020 21:22 # 15
ocaliptus
Hi, when you go to any Peugeot auto repair maintenance site, auto electricians turn on in 2 seconds, and you learn.
03.01.2025 18:34 # 16
Ucemcskn
It's been a while since this topic, but I'll tell you anyway, in case anyone else needs it. The headlight sensor or the auto-Man headlight mechanism is activated and deactivated with the headlight flasher. If I remember correctly, when you turn off the car while it's running, pulling the headlight lever fully once and releasing it activates auto, and if it was, it deactivates. Since I bought it, auto has been active once, somehow I disabled it. I turned it on from the multimedia system while researching, but when I researched further, I saw this in a source and tried it that way. The closed ignition flasher movement, in other words. Also, pressing the closed ignition wiper lever down once activates service mode, and the wipers remain upright. When it snows, or when you're driving downhill, press down once to change the wipers, etc. The 407 is a king car, you'll get in it and love it the more you get in it.
