Setting up 301 glass water
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 20:51 # 1
ottoman58
Hello. The glass water of my 301 vehicle is gushing at the very bottom. I removed it, cleaned it, but it's still the same. it just throws water to the line where the wipers stop. I would be very happy if anyone who knows the setting helps.
08.05.2020 20:51 # 2
KILIC
If there is no up-down adjustment, you can lift up with the pin tip and millimeter points. But you have to do this very carefully.
08.05.2020 20:51 # 3
ottoman58
If the [QUOTE = SWORD] setting is not up or down, you can raise it with a pin tip with millimeter points. But you have to do this very carefully. [/ QUOTE]
Actually, there is a place in the kenaej but I could not play back and forth. Let me try as you say. the teseteşekk
