sess incoming
08.05.2020 18:01 # 1
batuhan9292
Good day to you ... when the car starts at low speed or when you get off with a 2nd gear close to stop, when the dynamo pulley sounds like a civ civ flank from that side, besides, when it is wasted, the speed is high or it is doing it in a very little way again. Could the crankshaft pulley
08.05.2020 18:01 # 2
ahmet_bjk
It sounded like a timing belt to me. When was the last time you changed it?
It happened to me too. It sounded like a bird was singing out of the vehicle. The timing belt is worn.
The timing belt is a very important part. If the vehicle breaks while in motion, it will cause huge costs.
I think you should show it to a master as soon as possible.
08.05.2020 18:01 # 3
Eternal_Chaos
I have the same problem, but I don't think it's from the timing belt. Because it has been 12-13 thousand km and so on.
I'm also curious, frankly, it wouldn't be bad if we could find an answer :)
08.05.2020 18:01 # 4
kuscu38
IT IS FROM V-BELT OR IT IS V-BELT BEARING. WHAT IS THE VEHICLE?
08.05.2020 18:01 # 5
batuhan9292
I do not think the car is related to the peugeot 206 hdi 2007 model timing because it has been 2,000 km since the triger has changed and it was before that and this was not so ... I think the sound comes from the crank pulley or the tensioner balls ... but in general I wrote to be sure
08.05.2020 18:01 # 6
impact
I changed it after 2 thousand km, I started to do it again.
08.05.2020 18:01 # 7
kuscu38
I do not know how I was able to cut the sound hard as a result of a lot of work in the bearing, I do not know how it was, but it was not easy.
