Service suggestion for my Peugeot 206 XT Problems
08.05.2020 17:05 # 1
dRhkn
Hello friends. There are serious problems with my car walking, so I asked for your comments. I wonder your comments. How are the prices and workmanship? The engine is shaking, vibrating, even when I shift high, even the last muffler bumpers hit the engine. Purring is coming, it is only heard from the outside. A little arbitrary, a little bit of need.
08.05.2020 17:05 # 2
berk2309
Nice price for 598 pounds, but those used are always cheap, so cheap & nbsp;
08.05.2020 17:05 # 3
dRhkn
[QUOTE = berk2309] 598 pounds good price but the ones used are inexpensive, so cheap & nbsp; [/ QUOTE]
there is no torsion work alone in it
08.05.2020 17:05 # 4
berk2309
if not, the total sum of the paper is very nice price 598 lira but I don't think the pieces will be original & nbsp;
08.05.2020 17:05 # 5
loiz
If you do it in the industry, you will see the close amounts of 3 or 5 ... book it in the service, be comfortable .. don't be afraid to see them all in one pen ..
08.05.2020 17:05 # 6
dRhkn
[QUOTE = loiz] If you do it in the industry, you will see the close amounts of 3 or 5 ... book it in the service. I guess it wasn't a peugeot service, I went to the balçova industrial site in izmir. & nbsp;
08.05.2020 17:05 # 7
MagicPerformance
Others have not written the largest item, do not disassemble it without asking for normal torsional workmanship.
08.05.2020 17:05 # 8
dRhkn
[QUOTE = umutrizaergen] did not write the largest item, others do not disassemble the normal torsion workmanship without asking. [/ QUOTE]
According to the situation, the expense may increase, it may take half a day, I expect to take advantage of the said experience.
10-10 01:32:51
08.05.2020 17:05 # 9
Aziz
almost all of the top of the rear shock absorber line in the list, plus z rot - rod shaft - swings - right rear bearing, I replace the rear pads in the service right now, plus the parking sensor assembly, including the rod balance adjustment 400 TL (the sum of the parts is 310 TL excluding the sensor Most of them are made in Turkey, my shopkeepers are friends. I hope it helped & nbsp;.
