service mark
08.05.2020 16:50 # 1
ufuk..
good luck week to everyone .... 206 xt how to reset and reset the service and the mileage remaining on the panel in my vehicle and if you can help if you can have a peeler who understands peugeot on the european side of istanbul & nbsp;
08.05.2020 16:50 # 2
toga406
had a very simple forum method. But I forgot a little research, you find it is very simple to reset it.
If you search on google, you will find it again.
08.05.2020 16:50 # 3
Make a half contact, press and hold the button on the indicator and start with the other hand. Then count down from 10 will appear on the screen. When the count is complete, it will be reset.
08.05.2020 16:50 # 4
toga406
I tell you how I reset it in 2003 model 307, but I don't know how the same way is reset in 206.
Insert the key in the ignition switch, then press and hold the km reset button, and turn the ignition on in the second position. 10 seconds counting will appear on the screen. Wait by holding the button for 10 seconds until it is reset then 10,000 km will appear on the screen with a signal tone and the key sign will be deleted. Good luck.
& nbsp;
is an excerpt ...
< / span>
08.05.2020 16:50 # 5
toga406
buda visual expression
08.05.2020 16:50 # 6
toga406
I hope it will help. I think I have a similar method in all models
08.05.2020 16:50 # 7
ufuk..
Thank you very much, I will try ... do you have any advice that knows peugeot saglam be master & nbsp;
08.05.2020 16:50 # 8
ufuk..
There is a shortage of speed in the car. If I show it, the panel may be broken. The car is jerking when the car is running.
