Service for 2 times for each problem ..
08.05.2020 15:48 # 1
Golden
Hi forum people ..
I have 2004 model 307 HDI 1.4. I bought my car in February last year, I have been using it for about 1.5 years without problems. Until the trembling starts in the car ..
In line with the comments I have read here and from different places and the information I have received from 1-2 service points, I learned that the pressure pad and flywheel should change. On the recommendation of the acquaintance, I took it to a peugeot special service in Kartal. The operations were done, the gearbox went down, the parts changed, we took the car, we took a tour with the service worker, we noticed that there was a sound from the front team when it came to the pit in the turns. "The left tie rod head will change," he said, replacing it with a tie rod head did not receive money.
Anyway, I returned home, I used it for 1-2 days and the sound continued to sound. This time, he said, "We had to buy a new one." But a little sound continued to be heard.
Yesterday morning I got up and looked at the bottom left of the car. I called the service, "There was a small leak from the left axle seal, let's see." The voice in the car continued to come and I told him.
He changed the axle seal, the sound looked back to where it came, changed the ball joint, then I do not remember the name, did the two bars bent, corrected them, but the sound was really gone (2 times after the change of the rot head and the rot adjustments :)).
Anyway, I got back this morning and let me see what I got. The car continues to drip oil. I called and said, "Oil was leaking from the left axle seal.
For these problems, I went from Icerenkoy to Kartal 5 times. And I gave 180 rubles, axle felt, labor etc. Now a repair that will look again, I will pay 80-100 TL again. Unfortunately, it is solved when you go a second time for every transaction, but I don't think of going anymore.
So whatever it is, I just dropped the car to Bağlarbaşı Angle Oto so that I can no longer encounter any other problems in every repair. Let's see what they will cost ..
It was a little long, but I said relax. What is this friend .. When you say a problem is solved, that problem is not solved and another problem arises. No, indeed, the problems are on top of each other, but it is now common to get off from İçerenköy and go to Kartal.
Let me ask you this. Oil (or fuel I don't understand much) drips from the bottom of the bottom guard near the left wheel, and the bottom guard is pretty oiled. The axle has changed its seal, but it continues. Why do you think the problem is?
Thank you all ..
08.05.2020 15:48 # 2
Unfortunately, you have been the victim of an unconscious master. Let's get well soon. They will issue you a high bill with the authorized service, but your problem will be solved.
08.05.2020 15:48 # 3
metin
I think it was due to incorrect detection or incomplete workmanship.
I wish you had shared this topic before leaving the vehicle at an angle.
08.05.2020 15:48 # 4
Golden
[QUOTE = text]
You are right. But when I saw the same problem again in the morning, the blood splashed into my brain, so to speak: If it was going to solve the problem, let it be authorized, I would leave it in installments and pay.
They will call in the evening and tell the problem and how much it will cost. If I do not accept it, I will pay the 60 TL fault detection fee.
Do you have any idea what the problem is?
08.05.2020 15:48 # 5
Get well soon. Going to come and go, the insoluble and increasing problems are not desired, you may have exhausted your patience. As you have said, these malfunctions may be encountered. But there are certain problems that cannot be solved with certainty. I think this master does not look or see anywhere else while he is repairing a place, he does not peel it out if you can come back again.
I don't think you should try it again ...
08.05.2020 15:48 # 6
berk2309
Is your car automatic?
08.05.2020 15:48 # 7
qqyyxx
What kind of a specialist service is this? I take my car to the authorized service, but I have never heard of the fault detection fee.
The place where the dripping oil is likely is also the axle seal, which may be caused by poor quality material and workmanship. Get well soon. You're stuck in a chain of negativity.
08.05.2020 15:48 # 8
berk2309
I guess I changed the left axle, I changed it, you are there, there is a big chance.
08.05.2020 15:48 # 9
Golden
@ berk2309
My car is not automatic, manual gear.
@ qqyyxx
They had mentioned the same wage before when I went to ask Aç for something else. I thought the application is like this .. I changed the service axle seal, but I hope it does it again. because I'm really bored.
08.05.2020 15:48 # 10
Berk brother, there is no automatic in the diesel. Out in the 308s ...
Levent brother, I think you're lucky, fall somewhere. If the service is smooth, it will do whatever is required and deliver your vehicle to you. But I guess it will get a good figure. If he says 60 TL to the control, who knows what to write to the smoking ...
08.05.2020 15:48 # 11
berk2309
I asked him if I don't have cecoli or not, so I asked: D, but the big chance is the oil that is left-handed in the 307s.
08.05.2020 15:48 # 12
you should choose your master friend well. I hope the problem will be solved first.
respects
08.05.2020 15:48 # 13
Golden
[QUOTE = cecol of]
Levent brother, I think you're lucky, fall somewhere. If the service is smooth, it will do whatever is required and deliver your vehicle to you. But I guess it will get a good figure. If he says 60 TL to the control, who knows what to write to the stew ... [/ QUOTE]
Man, I am not very experienced in service, I said I would go to a familiar place, unfortunately.
If they make a very absurd figure, I will decide accordingly.
08.05.2020 15:48 # 14
[QUOTE = berk2309] I can't bind cecoli or not, I asked it because: D, but the big chance is the oil on the left side, it is problematic in the 307s.
Actually, there is no problem with the vehicles. Our services are our masters unconscious and sometimes the error is with us. If the necessary parts are changed at the required time, if the regular control is performed, the problem is the duser with the possibility of getting out ...
08.05.2020 15:48 # 15
metin
I wish you had contacted our sponsor, Şahin Şahin. sells original parts at a very affordable price. peugeot leave the service or even trained master friends were available.
08.05.2020 15:48 # 16
Golden
[QUOTE = text]
Is falcon peugeot selling parts only or parts + labor?
at least let me go somewhere reliable from now on.
08.05.2020 15:48 # 17
berk2309
valla cecoli I saw the presentation of peugeot, the master in his service does not understand from the pejo car. I do not understand how they give education.
08.05.2020 15:48 # 18
[QUOTE = Golden] [QUOTE = text]
He is a fragment. But it helps you because it has a proper environment. If you were in Europe, I would send you Masl * ga but it would stay away from you ...
Our brother Murat is called Umranıye ...
08.05.2020 15:48 # 19
[QUOTE = berk2309] valla cecoli I saw the presentation, peugeot's master in the service of the knle does not understand from the pejo car.
If I cry or laugh, I didn't leave it ... ConfusedEmbarrassedEmbarrassedEmbarrassed
There is no word to say ...
08.05.2020 15:48 # 20
Golden
[QUOTE = CeCoLi] [QUOTE = Golden] [QUOTE = text]
Thank you. Gülme
Page : / 2
