Service booklet
02.04.2021 19:06 # 1
berate38
First of all, I wish you a good day, I search the service manual booklet for the 207, the booklet on which bolt will be tightened with how many mm torque in the engine, and the booklet that says how many thousand of the oils and oils recommended by the factory will change.
I have the manual available, it doesn't write it.
Separate subject I did not want to open it, if there is a wrong situation, I can fix it. My vehicle, 2008 model gasoline, how many years the temperature sensor was deviating as below, it was below zero, then it was 20 degrees below the zero line even if it came out, it was falling below the zero line and the thermostat and the heat sensor were replaced with the original. The same problem again after a few days. He did this while the thermostat was changed, we said that the antifreeze should be changed and the heater core was removed, while the parts were dismantled, the spiral air hose connected to the air filter boiler on the engine was broken, we taped the broken place, which was hardened due to its age, we continued on the road, but the next day it gave an antipollution fault warning, the vehicle turned on the engine failure lamp. When I connect it to the pc, it gave the existing malfunctions and the story was a bit long. rim thanks in advance.
05.04.2021 09:20 # 2
Hello bro, what engine of the vehicle is 1.4 1.6. There seems to be a situation that causes a short circuit in the electrical installation or in the sockets. It's hard to find the service manual booklet in Turkish, brother. If there is English, you will probably find it in foreign forums, unfortunately.
06.04.2021 23:07 # 3
berate38
1.4 16v 90hp engine temperature gauge goes below zero sometimes does not show it.
07.04.2021 08:53 # 4
then the problem may be a break in either the socket pins or the electrical wiring of the system. Also, it is necessary to have the cigar box checked, sometimes there may be situations such as oxidation.
08.04.2021 11:59 # 5
berate38
Thank you, my teacher is getting stupid once in a while, there is no problem at the moment, I get on this way. I couldn't find the service manual booklet.
09.04.2021 13:06 # 6
I will do a research, if I find my teacher, I will send a link.
13.06.2023 12:40 # 7
Turan92
I've started having problems with the temperature gauge too. Sometimes it works normally without any problems, and sometimes it stays below zero and won't go up. There's probably a problem with the gauge itself, but I can't figure it out. Were you able to solve it?
