|   | Sequential System Gasoline Peak Drop |
| 08.05.2020 20:35 | # 1 |
|  ORhun53 | |
|  I had a new Atiker in-line system installed on my vehicle, but when the vehicle was in gas, it showed that the fuel tank had fallen to half the tank although it was full.  | |
| 08.05.2020 20:35 | # 2 |
|  Furkan979 | |
This is happening in all peugeot, so the problem is not very much, the vehicle does not know the LPG and thinks that when it turns around, it says gasoline will decrease and the road decreases the needle according to the fuel consumption in the computer. Do not worry. looking
| 08.05.2020 20:35 | # 3 |
|  ORhun53 | |
Doesn't it have a definitive solution, so that the gas chart doesn't fall?
| 08.05.2020 20:35 | # 4 |
|  sonerkyl | |
a normal situation on our vehicles. They solve this problem with lpg ciler psa module. But I think there is no need, my brother, I have lpf in 206 brokers, the gas tank is not over the top of the half tank, and it becomes the situation that should be at certain intervals.
| 08.05.2020 20:35 | # 5 |
|  bjkamil | |
I got used to it and now I have half a tank of gasoline. Sometimes when the light does not go up, I throw 50 TL gasoline and it goes up immediately.
| 08.05.2020 20:35 | # 6 |
|  Furkan979 | |
I think it is not worth trying to think of it, you will throw 50 lira gasoline and you will end    | |
| 08.05.2020 20:35 | # 7 |
|  mustafa881 | |
Pretty normal. do not worry...
| 08.05.2020 20:35 | # 8 |
|  tired06 | |
Gayat normal I had the same problem in other brand vehicles, not just something with pejo, honda, jaz, it was a tenth, audi was a tenth  | |
| 08.05.2020 20:35 | # 9 |
|  kayaca | |
I read your comments, I have the same problem, but I was a little under the half tank, I bought 150 TL of gas, I got full gas, I went 100km again, I filled the gas again, now it was 150 km, gasoline went down to 0, the gas is burning out, is this normal or not? Did I not understand the situation is normal?
