sente setting
08.05.2020 15:03 # 1
kaptan21
friends 98 model 306 gti car broke between the eccentric belt and the belt broke off .. now i bought a new set of valves and eccentric sets and made it in the rectifier so that it fits together, but this time the car does not accept the original sent setting, the engine's self-tuning engine works healthy but this time This time, the valve sounds out too much.
08.05.2020 15:03 # 2
peugeotefe
There is no question of not accepting the voiceover, you cannot start the car if it is off the clock. Your car's cylinder head has not filled the cups.
08.05.2020 15:03 # 3
kaptan21
Could it have damaged them when the strap broke?
kaptan21 2011-01-19 19:50:21
08.05.2020 15:03 # 4
peugeotefe
If the valves are damaged, there is a chance to break the cups
08.05.2020 15:03 # 5
tanilbakicimsit
get well soon bro
08.05.2020 15:03 # 6
kaptan21
[QUOTE = tanilbakicimsit] good night my brother [/ QUOTE] thanks friends
08.05.2020 15:03 # 7
kaptan21
[QUOTE = peugeotefe] If the valves are damaged, there is a chance to break the cups [/ QUOTE] so what do you suggest?
08.05.2020 15:03 # 8
dejavuer
my friend is the same
something happened to me, the timing belt was broken, the valve valves changed, the cover was made, but when it worked, the valve sounded repellent, I changed all of them again the same cover was removed again, we looked at the exhaust 2 valves were bent during assembly, now the cover was reconstructed we are waiting
is déjà vu 2011-03-02 16:34:34
