Sente Master
08.05.2020 21:20 # 1
ucanturk
Greetings,
My vehicle is 207 1.6 VTI Automatic.
Do you have any expert advice to adjust the sentence around Kocaeli?
08.05.2020 21:20 # 2
My brother does not easily escape the sentence in VTI engines because the timing is chain. If you are going to do this, it will not be such a master, because there is a special apparatus for the VTI engine. Processing without it can have worse results. The same engine was used in certain models, which could be a good bmw and mini cooper master. and definitely do this process with the apparatus I call the master.
08.05.2020 21:20 # 3
ucanturk
yes, unfortunately you are right. That's why I have trouble. Camshaft sensors fail. Both have changed, but the error persists. There is no possibility other than setting the sente, but I can not find a master to do. Is there any Anatolian side or Kocaeli?
08.05.2020 21:20 # 4
ucanturk
the problem has been fixed. Fault light went out. I just completed the missing oil of the car, that's all. Unfortunately, nobody understands anything from the industry.
08.05.2020 21:20 # 5
eran
[QUOTE = ucanturk] problem fixed. Fault light went out. I just completed the missing oil of the car, that's all. Unfortunately, nobody understands anything from the industry. [/ QUOTE]
Are you sure it is the exact oil? Stay on track for a while, may burn again.
08.05.2020 21:20 # 6
KILIC
So have you tried to delete the malfunction code that caused the malfunction light to come on? I think connect to a computer first, delete the fault codes. Look at him that he will burn again. I couldn't match the camshaft sensor malfunction with oil.
08.05.2020 21:20 # 7
ucanturk
it was as you said yes. The vehicle has not improved. It means that when the oil was completed, it went out by chance. The problem continues. I got it connected to the device gives 4 errors
P0014, P0011 Camshaft phasing error and P2168, p0170 fuel mix error. Eccentric position error. Unfortunately I couldn't find any understanding around here. Last week they exchanged eccentric sensors for me in vain
08.05.2020 21:20 # 8
https://www.otoyedekmarket.com/urun/peugeot-508-1-6-benzinli-elektrovana-orginal They changed this part hojam
08.05.2020 21:20 # 9
ucanturk
No, a piece has not changed. He never mentioned
08.05.2020 21:20 # 10
ucanturk
The electro valve also changed on Saturday. Thus, the money I spent exceeded 10 thousand TL. The problem still continues. I do not give my right to masters who earn money in the form of rip-plugs.
08.05.2020 21:20 # 11
Dogukan35
Is there a situation in your vehicle, like fluctuation at the first starter, stop, not eat gas at low speed
08.05.2020 21:20 # 12
Dogukan35
Did the chain stretch
08.05.2020 21:20 # 13
eranstone
My vehicle is the same, for now my expense is around 3 thousand. I am on my way to 10 thousand. The problem is similar to yours. We look forward to friends who have found a solution
08.05.2020 21:20 # 14
omerb
Hello, according to an overseas article, the oil and oil solenoid valve for p0011 code has been emphasized. If this valve is blocked, if the oil line to the valve is blocked,
If the oil is too thick, if the oil filter is clogged, it will cause problems. It looks like your fault is like this. Because you said I put oil, it improved. Have this oil solenoid checked. In the article, the line said 1, and section 1. I don't understand what he meant. 1. I didn't know if it was a cylinder or something.
omerb 2019-10-31 20:07:36
08.05.2020 21:20 # 15
ucanturk
it improves when I add oil or change completely, but it is the same after a day. Now the situation is developing, when the camshaft sensor pulls out the plug, the vehicle becomes like a clock, it detects when you plug it in. The sensor has changed but the problem has not changed. It says something like a position error on the computer. The master will now look at the sente setting. He wants three or five thousand. Let's do good work.
Let me tell Bi the valuable filter about oil.
08.05.2020 21:20 # 16
omerb
Your problem seems to be related to oil pressure. Have you had an oil-related procedure before this problem occurred? What did you do before the breakdown? I think this setting is not something that escapes on its own. The most important factor affecting this is oil pressure. Things like filter, oil cellophane. You can try to show it to someone different. What drives me here is that it is normal even if it is one day after changing the oil.
You can measure the oil pressure. Change the filter. Cheap.
Please read the link below.
08.05.2020 21:20 # 17
ucanturk
thank you all for your interest.
Coils spark plugs oil oil filter changed twice. Electro valves, oil vapor hose, eccentric sensors changed, injectors changed. Then they said the cable was burnt. It worked well for three or four days, but the fault light was on and eccentric position error was giving errors P0011, P0014, p0170, p2178. Now the top cover has been opened. The master couldn't find anything there. This master made it again, someone did it again. He will do it again with the original apparatus from the service.
How many masters are all changing parts. I went to a Bi master in Kartal and he just served to pay. I really couldn't find a place to take.
08.05.2020 21:20 # 18
omerb
I read the publications for you like crazy. Generally called 1st Cylinder error. One of them cleaned the problem of the first cylinder injector cable that has seen rust. Already your error code is always called bank 1. Whichever is the first cylinder looks at its injector wires. Only some craftsmen mix the first and 4th rollers. Your problem seems to be cable failure. Replace this burnt cable, injector cable, etc. Hope you will solve it.
08.05.2020 21:20 # 19
ucanturk
Thank you very much, do not be missing.
Complete installation had been checked before. They said that they burned the cable near the exost. If not, let's completely replace the engine compartment installation. Let me tell the master. He's already been in the car for two weeks
08.05.2020 21:20 # 20
ucanturk
It is expected to arrive at the original sentence now. Yesterday the teachers came and looked at the electric vehicles course. They made measurements, they couldn't find anything related to electricity or electronics. There was no abnormality under the top cover. Everyone's prediction is on sentence. I'm waiting helpless. If not, I will remove the LPG and leave it for service.
Page : / 2
