sente adjustment and knock sensor
08.05.2020 18:44 # 1
Hello friends . What happens if the sente setting and the knock sensor fail? What happens if it is repaired? thanks in advance.
08.05.2020 18:44 # 2
Ali1905
If the knock sensor fails, the vehicle will start burning, knocked down, if the adjustment is broken, it goes up to take the engine.
08.05.2020 18:44 # 3
My vehicle is the Peugeot 307 1.4 HDI. Some friends say it doesn't exceed 150 km when the sentence setting and knock sensor are broken. Is it true? If anyone knows, please write a message. Already have location (peugeot 307 does not exceed 150 km) http://forum.peugeotturkey.com/forum_posts.asp?TID=35601&title=peugeot-307-150-kmyi-geciyor peugeot 307 1.4 HDI 2014-07-26 18:30:25
08.05.2020 18:44 # 4
someone to help friends?
08.05.2020 18:44 # 5
Efe-Pojo
If you have changed the timing belt recently before this problem, it is very likely to be from the sentent setting, but if you have not made any changes, the sentence setting will not be distorted automatically.
08.05.2020 18:44 # 6
[QUOTE = Efe-Pöjo] If you have changed the timing belt recently before this problem, it is likely to be from the sentence setting, but if you have not made any changes, the sentence setting will not be distorted automatically. [/ QUOTE]
Yes, I changed the timing belt. Could it be from him?
08.05.2020 18:44 # 7
Efe-Pojo
[QUOTE = peugeot 307 1.4 HDI] [QUOTE = Efe-Pöjo] If you have changed the timing belt before this problem, the changeover setting is very likely, but if you did not make any changes, the sentence setting will not deteriorate automatically. [/ QUOTE]
yes the sentence has escaped, the master most likely did not understand the pejo, show it to the pejo master.
08.05.2020 18:44 # 8
[QUOTE = Efe-Pöjo] [QUOTE = peugeot 307 1.4 HDI] [QUOTE = Efe-Pöjo] If you have changed the timing belt recently before this problem, it is very likely that it will be from the sentence setting, but if you have not made any changes, the sentence setting will not deteriorate spontaneously. [/ QUOTE ]
thanks.
08.05.2020 18:44 # 9
Doesn't it exceed 150 km when the sente setting escapes?
08.05.2020 18:44 # 10
Wouldn't it exceed 150 km when the sentence adjustment and knock sensor fail?
08.05.2020 18:44 # 11
derman362
Knock Sensor Detects the Misfire Cylinder and Shifts Its Advance.
2.Sente Adjustment `sente adjustment` The so-called adjustment is the timing of the Eccentric shaft and the Crankshaft with the belt.
and if the timing is broken, that is, its synthesis escapes;
Does not hold 1 roll
Absolutely not pulling on 2 ramps
You can never get the power you want from 3 cars ...
08.05.2020 18:44 # 12
[QUOTE = derman362] Knock Sensor 1 Detects the Rolling Cylinder and Shifts its Advance.
Yes, I can't get the power I want from the car. I do not pay any attention to idle. Absolutely faded because I changed the timing belt. The master said okay. He didn't mention the setting of Sente.
08.05.2020 18:44 # 13
derman362
So the sound of your car has changed or something. Excuse me (is it stupid?)
08.05.2020 18:44 # 14
[QUOTE = derman362] So Your Car's Voice Has Changed So So Excuse me (Is it idiot?) [/ QUOTE]
The sound I made service to my vehicle was heard before. The sound started to come out a little bit, it was time to serve, it has been 6 months since the oil has changed, the oil has darkened a lot. Smile
08.05.2020 18:44 # 15
Efe-Pojo
You get the car, take it to the service, change the oil and adjust the sentence, there will be no master. I looked in Cyprus, there are 6 authorized services take it to someone.
08.05.2020 18:44 # 16
derman362
Brother, there is a lot to be talked about, as your friend says, they take care of the service and the extensive test. They can cause a lot of sensors, Turbo electrovalve etc. etc. But first, go to the service.
08.05.2020 18:44 # 17
help
08.05.2020 18:44 # 18
up to date!
08.05.2020 18:44 # 19
update
