Sensor Failure
08.05.2020 14:08 # 1
higungor
Rain and headlight sensors are not working on my 2005 model 307 xt. 5 seconds to the left arm. I press it as far as I know, the headlight sensor should be active, but there is no message on the trip computer because it is active (or rather, nothing happens). The rain sensor does not work the same way. Why is the estimated cost incurred?
08.05.2020 14:08 # 2
yzt06
hello ... to turn on the headlight sensor, you need to turn the car key once (i.e. only with the battery sign lit) and hold it on the left arm for 5 seconds ... if you do this while the car is running ... let me try to inform you about the rain sensor according to the result of a try
08.05.2020 14:08 # 3
higungor
[QUOTE = yzt06] hello ... you have to turn the key of the car once to turn on the headlight sensor (i.e. only the battery sign will light up) and hold it for 5 seconds. [/ QUOTE]
& nbsp;
I tried unfortunately does not work
08.05.2020 14:08 # 4
yzt06
When you first remove the cover behind the rearview mirror and take a look at the sensor's socket ... there may be a lack of contact ... maybe it is completely unplugged .. because it does not react at all your sensors: d
08.05.2020 14:08 # 5
higungor
I would check in the evening and write again, thank you for your interest.
08.05.2020 14:08 # 6
hasimayaz
There is a fuse for the sensors. In both sensors, the fuse looks at the moment. Find and check in the user manual. It should be in the in-car fuse box. You can get help from the link below.
& nbsp;
08.05.2020 14:08 # 7
higungor
[QUOTE = hasimayaz] There is a fuse for the sensors. Both sensors look at the fuse instantly. Find and check in the user manual. It should be in the in-car fuse box. You can get help from the link below.
& nbsp;
Hasim brother checked the fuses all solid
