semi-automatic transmission oil change |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:59 | # 1 |
| 08.05.2020 16:59 | # 2 |
monur |
The way to solve your problem in reverse gear is not oil change. The problem is caused by 3 parts. 1- Top, mator wedge 2- Transmission wedge (the place attached to the trauma) It cannot be understood without dismantling, but 99% shears the shaft inside it. 3- Reversing band Have it checked in order, your problem will be corrected in 1 and 2 at the latest.
