Sell 307 and get C4 crashed?
08.05.2020 18:36 # 1
tolga.onal
My friend, who was sitting right next to me at the workplace, had an accident over the weekend and sells his car. 2005 Model 67.000 km gasoline automatic worn out cockpit in a clean car that has no fault in its flooring, the car stays in the car when it gets on the car. As soon as the accident happened in Çanakkale, one of the German plates Audi scrapped the front of the car. ABS Brain Side airbags radiator hood bumper headlight and essential parts need to be replaced. They say there might be a problem with the gearbox. Now it sells the vehicle for 12,000 TL under these conditions. Is it worth it to sell my 307 and give it 12? They say that there will be a cost like 9 thousand TL, but I think I will make it cheaper, after all, there is no play in the chassis that did not hit the head, scattered around the corner and scattered the front part of it.
08.05.2020 18:36 # 2
tolga.onal
In addition, the vehicle has a headlight sensor, parking sensor, rain sensor, 8 airbags and many more features.
08.05.2020 18:36 # 3
Serkan
First of all, I wouldn't bother personally.
08.05.2020 18:36 # 4
tetik-soner
making such cars, my patience friend ... find that part find this part ... master will be good biker ... if you say hee, my time will lie in the industry, get up and take time ... but a situation that requires time and effort ...
08.05.2020 18:36 # 5
tolga.onal
There are places where I will supply the parts, I will give my own master, the car establishes the connection between the makers and the master. I stay without a car for at least 15 days. - The car is really clean. It is very clean. Mersin plate is 1 year younger than Istanbul and 2 years younger than my car. So if I try to attach the extras to my car, I will spend at least 3-4 thousand TL and my car will not be 2 years younger nor can it fall to 67 thousand km :) Only the bonnet and the bumper need the bonnet and the rest is mechanical expenses. I do not change the side airbag, put a resistance and turn off the airbag lamp, the air on the left side will be without a pillow.
08.05.2020 18:36 # 6
emrepunar
If you climb up to 9 thousand, put it in the press, it is not clear what will come out on a motor vehicle that is eaten in front of you. a ton of trouble, etc. vs. Let me give you the simplest example of my brother's 2010 mazda3 just hit the bottom sewer cap on the changing parts of the ears of the engine, the lower protection gearbox repair airbag repair did not take our total labor 4 billion. except workmanship. some very small pieces can hold a lot.
08.05.2020 18:36 # 7
tongucuk
If you are satisfied with your own vehicle right now, I think there is no need for fantasy, and if you try to sell a vehicle with a crash, you can not sell it tomorrow. I say be
08.05.2020 18:36 # 8
tolga.onal
I do not think I will use it for a long time, the reason I want to buy it is because it has been 2 years since 307 but I thought that I would change it now, but it is a risky situation, you collect everything, you start marching, another problem, as you said, adventure job is a little bit. I was convinced that it would be profitable to collect and ride C4, it was both 2 years young and a half-car and full car, but I guess there is no need to hurt the head without pain :)
08.05.2020 18:36 # 9
tongucuk
Clap
08.05.2020 18:36 # 10
pusutr
So to speak, you are still saying that the car has officially gushed out the bowels. Bravo. Clap
08.05.2020 18:36 # 11
ercn86
The car's back is still out, you are still miles, you say clean :) You have no other job to do.
08.05.2020 18:36 # 12
ahmed206
Yes, aga, there is no way out of this car, you will spend a lot of time doing it, and you will spend a lot of it. If you are going to get the accident, the hood should be clean if possible.
08.05.2020 18:36 # 13
tolga.onal
Thank you for your ideas, friends, but it was clean, as if the car was good :)) I wrote it here or else I was thinking seriously. Thank you everyone.
08.05.2020 18:36 # 14
serkomser
Contagion My Tolgacım will not be clear what will come out!
08.05.2020 18:36 # 15
fætih
the literature of the car has shifted. the head is dizzy. The car that was hit by the side is after all. I did not get the accident of the car that I bought after 23 to 24 24. you can get it if you cost it 16 17 ...
08.05.2020 18:36 # 16
simirnoffredbull
If you search a bit you will find the same 21-22 :)
08.05.2020 18:36 # 17
ahmed206
And look at that cee ?
I don't bother but it looks like there's not much damage
08.05.2020 18:36 # 18
tongucuk
they say the stew of cheap meat becomes sour
now this vehicle is probably a tiny game of galleries attached to the cursors, as the parts that are damaged from the front are usually made. knows how the engine
Consider this, if this man in the car dealership does not know much about this man, he doesn't know why he can easily be collected and ride at low cost. The 2012 model does not make himself a comfortable 33-35 thousand in 32400 km why he does not sell himself and sell 30 thousand.
my idea is not to get into these types of vehicles at all, if you have 25 thousand in your pocket, it is most logical to look at the 25 thousand car.
08.05.2020 18:36 # 19
cansytnn
bad car business age I think if your car is enough for you, do not get infected, do not get infected, see another vehicle, I say these words as a burning mouth of milk
08.05.2020 18:36 # 20
ahmed206
Well then we do not recommend it to anyone, thank you.
Page : / 2
