self-gas problem
08.05.2020 17:16 # 1
dukenukem82
My friends had given gas to themselves once in the cold last winter. It was supplying gas until 2000 times, it remained for 15 minutes and then it was recovered when it was closed and opened yesterday. The heater core was leaking water from the orings and I got it done and came home. The vehicle started to gas once in a while when it went out in the evening. In a week, sometimes it does not fall and stop while cruising. & Nbsp;
Where do you think the problem is? Could I be an idler or something?
08.05.2020 17:16 # 2
dukenukem82
No problem in cold engine when it is hot. Either it stops or rises up to 2000 rpm. The idle improves temporarily when it is restarted a few times. & Nbsp;
08.05.2020 17:16 # 3
falan
If the situation does not change in gasoline and LPG, it is most likely idling engine .. original 250-300 around sub-industry 50-60 .. I recommend you to install original ..
08.05.2020 17:16 # 4
dukenukem82
If we repeat the problem with detailed throat butterfly cleaning, we will try the temperature sensor lambda and idling valve one by one. & nbsp;
08.05.2020 17:16 # 5
falan
You can not get efficiency with cleaning.
08.05.2020 17:16 # 6
dukenukem82
What should we do then?
08.05.2020 17:16 # 7
selammedikal3434
I did what you said, my friend. I cleaned it, sprayed it, there was not a gram of dirt left and my problem was solved. For now, there is no problem but what happens, it stays in my trunk and I spray the lint pad. I do not think it will be a problem, but if it does, I will spray my spray for 2 minutes :)
