self-gas of the vehicle
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 17:22 # 1
savasbaser
If anybody knows friends, please write to me, I have a 406 car with a 1997 model & nbsp;
& nbsp; 1997. 40 liters of 110 hp gasoline. >
When I press and release the gas while driving normally, let me know if the car can cause itself to shake & nbsp;
& nbsp; thanks in advance
08.05.2020 17:22 # 2
GarajTurk
Have your gas pedal sensor checked.
08.05.2020 17:22 # 3
falan
high probability idling engine needs to be changed .. estimated number is between 150-200, but there are those in the market with supplier industry, they are much cheaper but I definitely recommend you to buy original.
08.05.2020 17:22 # 4
savasbaser
I changed the idling engine, but it still hasn't improved
08.05.2020 17:22 # 5
falan
Hmm then there may be an air leak in the butterfly throat or a gas wire shortage. have to investigate.
08.05.2020 17:22 # 6
Zagorka
I agree with the stuff, if the throat butterfly is idle, it is most likely
08.05.2020 17:22 # 7
artes34
My friend had the same problem in my car. It turned out to be from the butterfly throat. Look at the butterfly throat.
08.05.2020 17:22 # 8
nurkann
It was one of the problems below, butterfly cleaning was done first, the problem continued, the idling engine was replaced with the original 350 TL equivalent. (additional information: I have a more serious idling problem after the idling engine has been replaced. The idling of the car has not been resolved in cold weather in an extremely low way. The problem disappears slowly after the car warms up)
