Self-dipped beam turns on and off
08.05.2020 20:23 # 1
niklaus
Hello friends, in the incident that happened to me today, while the vehicle was driving for a short distance, the dipped headlights of the vehicle turned on, then turned off after 2 seconds, after 2 hours, I encountered the same problem again, on the way it went out, it started to burn again, repeated 2 times.
08.05.2020 20:23 # 2
whisky
If the headlight sensor is available, I think it may have been in your car, maybe it has a problem or it is from fuse but only my opinion is in this direction. There are friends who know better.
08.05.2020 20:23 # 3
Popomundo
This kind of fuse can not happen from the headlight arm, peugeot in ...
08.05.2020 20:23 # 4
headlamp signal arm faulty teacher needs to be replaced. There is a cost of around 500-600 TL, only the material workmanship does not want more than 50 TL.
08.05.2020 20:23 # 5
whisky
[QUOTE = Popomundo] This kind of fuse can not be done from the headlight arm. can be from bsi.
08.05.2020 20:23 # 6
niklaus
Anyway, if the fault does not find us, will we have any solution if we disassemble com 2000i and apply contact spray? Bidet, I'll take this signal arm just as a part of my arm, or will I be in the whole state, including the eraser joystick?
08.05.2020 20:23 # 7
[QUOTE = niklaus] Anyway, the fault will not find the clatter, would we have any solution if we removed the com 2000i and sprayed the contact spray? Bidet, I'll take this signal lever just as a part of my arm, or is it the whole one, including the eraser joystick? [/ QUOTE]
unfortunately the signal arm is not sold separately. com200O sold completely. some electronics can have a boom. There are people who have places to call and ask.
08.05.2020 20:23 # 8
niklaus
As a result of my researches, Soner teacher; peugeout 307 headlight signal lever is sold in strip form as a single for 114 tl here.
http://www.hepsiburada.com/wolcar-peugeot-307-far-sinyal-kolu-seritli-p-hbv000002ıfnt?magaza=wolcar%20otomotiv&wt_gl=cpc.tum.genel.pla&gclid=cjwkeajwpdnjbrc4hctftc6fweksjabwupni91tifcvcfseogtxoalmp3no0z5homsmthbfq3pwhkxoc6fjw_wcb Niklaus 2017-06-07 00:09:35
08.05.2020 20:23 # 9
emrahyilmaz84
I sprayed it for 1 year and managed it at 307 1.4
08.05.2020 20:23 # 10
[QUOTE = niklaus] As a result of my soner teacher research; peugeout 307 headlight signal lever is sold in strip form as a single for 114 tl here.
http://www.hepsiburada.com/wolcar-peugeot-307-far-sinyal-kolu-seritli-p-hbv000002ıfnt?magaza=wolcar%20otomotiv&wt_gl=cpc.tum.genel.pla&gclid=cjwkeajwpdnjbrc4hctftc6fweksjabwupni91tifcvcfseogtxoalmp3no0z5homsmthbfq3pwhkxoc6fjw_wcb [/ QUOTE]
the problem is likely to be fixed, you need to find a good electronics engineer to install it. The price is expensive, it seems to me that Aliexpreste is more affordable in 15-20 days.
https://tr.aliexpress.com/item/free-shıppıng-for-peugeot-307-301-308-3008-206-207-405-407-408-807-rcz-ındıcator/32611920068.html?spm= 2114.010208.3.49.nn880p & ws_ab_test = searchweb0_0, searchweb201602_5_10152_5010012_10065_10151_10068_10136_10137_10060_10138_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_10096_10052_10053_10142_10107_10050_10051_5030013_10172_10084_10083_10080_10082_10081_10110_519_10111_10112_10113_10114_10182_10078_10079_10073_10123_10189_142-10051_10102, searchweb201603_16, ppcswitch_2 & btsid = 8ccc2f4d-df06-4dbd-9db9-5b0f75a581cb & algo_expid = 913845cf-87f9-434f-a111-1ceb61db2205-6 & algo_pvid = 913845cf-87f9-434f-a111-1ceb61db2205
08.05.2020 20:23 # 11
niklaus
Thank you, soner, the cost has decreased significantly :)
08.05.2020 20:23 # 12
axoyum
I had the same problem.
the master dismantled in his hands. He settled for 100 TL.
He said that if he did not have it, the arm would be 114 TL and I would get 50 TL.
08.05.2020 20:23 # 13
Mehmey
friends, I went abroad for 3 months, the car lay down for 3 months, when I arrived, the headlight signal screen light started blinking on your own when you signal it. no problem cost 20 tl
