Self-Burning Headlights
08.05.2020 17:11 # 1
extremex16
Good evening everyone, I will help you talk about my two problems. My car 2005 Model 307HDI 1.6 yesterday I got out of the car, locked the doors, went home, when I returned to the head of the vehicle, dipped headlights were not lit.If the indicator shows how much warning light is on, the doors do not open with the control. Another problem is that when I turn the steering wheel to the left, the airbag light is on. I am waiting for your help. & Nbsp;
08.05.2020 17:11 # 2
Serkan
Sir signal, wiper horn, com2000 unit to which airbags are connected is probably chronic in 307s unfortunately
08.05.2020 17:11 # 3
extremex16
I figured out if the com2000 can light the headlights on its own, one headlight comes on every 15-20 minutes and the indicator lights are all on.
08.05.2020 17:11 # 4
feline
I think you can remove the battery pole head tonight
08.05.2020 17:11 # 5
Serkan
[QUOTE = extremex16] I understand that if the com2000 can light the headlights by itself, one headlight is on every 15-20 minutes and all the indicator lights are on. [/ QUOTE]
I do not have a clear knowledge of that, unfortunately.
08.05.2020 17:11 # 6
extremex16
Right now I have removed the pole head but how do I lock the doors, the room is another problem, thank you very much for your attention, guys. "/>
08.05.2020 17:11 # 7
Serkan
[QUOTE = extremex16] I removed the head of the pole right now, but how do I lock the doors, the room is another problem, thank you very much, guys. I wonder if I put the padlock on the doors "LOL [/ QUOTE]
I will say mass first, then remove the pole, but you cannot open the doors without installing the pole.
08.05.2020 17:11 # 8
badcombatant
& nbsp; BSI may have received water. Recommended emergency check. I just happened to have the same problem, I hope. Open the cover in the lower left corner of the steering wheel. Go to the electrician you trust or the pug special service that you trust.
I am saying this is the issue that I criticize the peugeot brand as the only negative thing I have, I think what makes a hole that can enter water just above a very important piece like BSI (although it has a tap) makes sense. does not seem to have an explanation.
08.05.2020 17:11 # 9
extremex16
& nbsp; I have already gone to the cerebellum in the bursa on suspicion today. I don't know. Battery and & nbsp; xenon headlights & nbsp; arrived but the zones were installed in the vehicle for a year.This fault happened after loading the vehicle yesterday, so after using it in the range of 3500-4500 rpm. Let's see what happens after 20 minutes. & Nbsp;
08.05.2020 17:11 # 10
extremex16
Friends solved my problem.If there is a short circuit continuity in the electrical installation, bsi is surprised. It turns on all the warning lights in the indicators. The short circuit in me is deflecting bsi because of the daytime running lights in my headlights. I have removed the lamps right now. # 111; ngue "title =" T o ngue "/> thank you, my dear forum friends.
