Self-Burning Headlights.
17.08.2020 19:57 # 1
Brcbyrktr
Good Evening Friends.While coming home from work today, I saw the reflection of my headlights at the rear of the vehicle standing in front of me. I thought I had opened it by mistake, but it was closed on the arm. When I turned it on and off the handle it turned off. I wonder if Biyerden is doing something like a chase .. I am waiting for the help of the friends who came to him and found the solution. Thank you in advance.
18.08.2020 19:36 # 2
talip206
It looks like the classic com2000 headlight indicator stalk. Do you have a loose contact problem in the signal?
19.08.2020 08:15 # 3
Ditto classic headlight signal arm failure (com2000)
19.08.2020 22:27 # 4
Brcbyrktr
I can't notice the lack of contact, but when I turn right and turn the steering wheel to straighten, it switches itself to the left signal.
20.08.2020 20:39 # 5
talip206
[QUOTE = Brcbyrktr] I can't notice the lack of contact, but when I turn right and turn the steering wheel to make it straight, it switches itself to the left signal. I solved this problem myself. A situation that requires some manual skill. A situation caused by the melting of a simple plastic inside the signal arm over time.https: //forum.peugeotturkey.com/forum_posts.asp? TID = 46885 & title = 206-com2000-signal-arm-repair talip2062020-08 -20 20:42:55
