selector problem
24.11.2021 14:04 # 1
Sametmutlu2958
hi As you know, the selector lever will light up when you press it a little in two steps, and when you press it a little more, the longs stay open, 1 stage does not work in my vehicle.
25.11.2021 10:57 # 2
Sametmutlu2958
Can anyone help ??Cry
25.11.2021 11:24 # 3
Sametmutlu2958
Is it a bug that nobody knows about Clap
25.11.2021 11:35 # 4
Hello,
The problem is probably in the arm, it seems that the teacher needs to be replaced, the second possibility is that the relay may be faulty.
25.11.2021 11:37 # 5
Sametmutlu2958
Do you know where his role is, I'm an electrician, maybe you can take a look and try something.
25.11.2021 12:00 # 6
As far as I remember, it should be integrated into the bsi bro, you need to look at the diagram, but if you burn the long ones normally, it's probably a problem in the arm.
26.11.2021 16:45 # 7
talip206
It looks like there is a problem with the arm. There are copper plates on the end of the arm, they are probably bent.
