Selector lever
08.05.2020 15:56 # 1
deamod
Guys, I have a signal that I turn left now when I turn the steering wheel to bend and turn the arm alone. When I give the signal to the right, it is not like that. Is there a solution for this or will the arm be changed?
08.05.2020 15:56 # 2
When you give my signal to the right and straighten the steering a little bit, I give the signal to the left and even to the right.
08.05.2020 15:56 # 3
deamod
[QUOTE = HuseyinTurk] When you give my signal to the right and straighten the steering a little bit, the signal to the left is not working on its own or even to the right. [/ QUOTE]
:) :) look at the indifference, we do so, the lions are so costly, we have to go to the source of the malfunction, we have to sit and talk, we have to go to the factory (childhood), after all, why should the car become a huge man at the age of 12? I gotta do not understand ... Embarrassed
EmbarrassedEmbarrassedEmbarrassed
Embarrassed
08.05.2020 15:56 # 4
metin
just like mine, when he gives the signal to the right, he collects the steering wheel and turns the signal to the left.
08.05.2020 15:56 # 5
metin
[QUOTE = deamod] [QUOTE = HuseyinTurk] When you give my signal to the right and straighten the steering a little bit, I signal to the left on my own or even the right signal is not working from time to time [/ QUOTE]
Embarrassed [/ QUOTE]
Are you studying child education or something? Kahkaha
08.05.2020 15:56 # 6
deamod
no bro brother fasting from fasting :) my head is so blurry i'm afraid of not collecting the engine so that time passes, i'm afraid i'm gone :)
08.05.2020 15:56 # 7
deamod
In the meantime, we completely got out of the issue, yaw not knowing the cause of the fault can be corrected :)
08.05.2020 15:56 # 8
metin
[QUOTE = deamod] No, brother, from fasting fasting :) I am afraid of not being able to collect the engine in order to let the time pass by, my head is very blurry.
Kahkaha
08.05.2020 15:56 # 9
metin
I would say contact spray if it is electronic, but it must be a mechanical problem.
have existed since time immemorial.
08.05.2020 15:56 # 10
deamod
walla I have been doing it manually since I bought the car. Looks like it, but never :)
08.05.2020 15:56 # 11
metin
I wonder if there are any other 206's. For example, when it signals to the right in our 307s, it closes the signal and collects it to the left. But if you collect very slowly, it will work normally.
08.05.2020 15:56 # 12
The same problem was discussed 4 days ago. Though the issue was over 307, but it doesn't matter.
From here: http://forum.peugeotturkey.com/forum_posts.asp?TID=16786&KW=scotch&title=sign- problem
Koliva 2011-08-05 16:54:12
08.05.2020 15:56 # 13
deamod
We do not have the same problem, we are alone, when the arm gives signal to the left, it works when it gives to the right, it does not throw completely different subjects, while you are gathering, the signal is left and me does not throw right side is completely different topics.
I am waiting for the upcoming posts, friends
08.05.2020 15:56 # 14
deamod
Friends, I'm waiting for help
08.05.2020 15:57 # 15
So, does it sound ticking while freezing the steering wheel?
08.05.2020 15:57 # 16
deamod
It does not come, but I have to take 2 or 3 laps. It does not make it as comfortable as the left signal for auto-throw, but it is also right, but as I said, I need to do 2 or 3 laps.
08.05.2020 15:57 # 17
metin
[QUOTE = deamod] It does not come, but I have to take 2 or 3 laps. It does not make it as comfortable as the left signal for auto-throw, but it is right, but as I said, I have to do 2 or 3 turns.
It was very interesting, I wondered. I would do it if someone dares Kahkaha
08.05.2020 15:57 # 18
maestro
08.05.2020 15:57 # 19
tayfundoner
brother bursa there is text peugeot in the small industry, show it to you if you want to repair it only if you want to repair it, if you want to go show it, you will be sure that it will be sure you will be satisfied.
