selector lever ???
08.05.2020 17:38 # 1
korkusuz202
hello friends 206 left signal on my vehicle when the lever is halved, it gives a left signal, but when I lower it down, it does not give a signal ... right signal is not a problem either but this left signal gives a signal when I hold it halfway through ... How do I fix the problem ??
08.05.2020 17:38 # 2
herry
It is difficult to repair, I recommend you to replace it from the service, not the new one is very expensive. I did so a few years ago. I think it had a price of 70TL.
08.05.2020 17:38 # 3
korkusuz202
it costs 100 lira with craftsmanship.
08.05.2020 17:38 # 4
MemoTech
http: // www.peugeotmarket.com/206-FAR-KUMA-KOLU-KOMPLE-COM2000-ORJINAL,PR-895.html
280TL change gives 20TL even 300TL < / div>
08.05.2020 17:38 # 5
herry
The man said only a signal, 70 TL signal arm, if the new one is 30 TL, 100 TL. I think it is unnecessary to replace all of them. If it works, don't touch the others. if it breaks, it will change them in the future.
08.05.2020 17:38 # 6
MemoTech
[QUOTE = herry] the man just said the signal, 70 tl signal arm would be 100 tl if the new one was taken at 30 tl. I think it is unnecessary to replace all of them. If it works, don't touch the others. if it breaks, it will change them in the future.
You don't need to take any tension, & nbsp; Thank goodness & nbsp; I have no problem. If you know that your friend's vehicle has no COM2000 unit, you will answer.
Since the model of friend's vehicle is 2003, COM2000 unit is available and it is a single unit. When one of the elements of this unit needs to be malfunctioned and replaced, the control units (connection slots) of the Headlamp, Signal - Wiper Arms, Horn and Airbag control, Cruise Control and Radio Control Arms will be changed together.
