Secondary Air Pump Malfunction
08.05.2020 21:19 # 1
samizeldestan
Hello friends. My vehicle is 2.0 automatic gasoline + LPG. When I look at the fault codes from the phone, it gives the fault code related to the secondary air pump. What's the problem? Where exactly is the pump it calls? Sometimes the vehicle does not notice LPG or gasoline, and both have low torque. So I press the gas, but the moment does not accelerate. Of course this does not always happen. Can such a problem arise from the secondary air pump?
08.05.2020 21:19 # 2
This is the first time I heard it from you, my teacher, but it looks like it exists. actually it would be better if you write down the fault code. Looks like a bit expensive piece. I don't know how much it affects the engine.
08.05.2020 21:19 # 3
samizeldestan
[QUOTE = sonerkyl] I heard from you for the first time, my teacher, but it looks like it exists. actually it would be better if you write down the fault code. Looks like a bit expensive piece. I don't know how much it affects the engine. [/ QUOTE]
P0413 teacher fault code
08.05.2020 21:19 # 4
Dogukan_3002
Bid on facebok pejo forum let's see
08.05.2020 21:19 # 5
samizeldestan
[QUOTE = Dogukan_3002] Bid on the facebok pejo forum let's see bi [/ QUOTE]
I asked there. There are those who say that I am so 407 masters but no answer
