Seat squeak
08.05.2020 14:10 # 1
I just joined your friends, I have a problem I hope you can help:
A slight squeak comes from the driver's seat when I enter a pit or a motorbike on the super-damaged roads of Ankara (which is not possible). Is there a solution to this, or is there a place you can suggest to solve it in Ankara. Indeed, driving was a crush, I listen to the car directly, it is annoying sound.
My vehicle: Pug 407 1.6HDI Executive
08.05.2020 14:10 # 2
Murat
First of all, welcome.
As you said, I do not understand how these sounds come from our tools in these ultra luxurious, excellent roads of Ankara.
A sound of joke is coming from somewhere kessen, when you say kessen from the other side, there are already annoying sounds from all over the vehicle.
I think 3m or wd40 has a dirt rust remover material, it can also be used in places with squeak.
You can squeeze this into the creaking connection portions.
If there is no solution, you can get it done by auto upholsterers.
08.05.2020 14:10 # 3
vbmaster
I think the squeak comes from the adjustment arm, not the seat. I think the spray my murat brother says will work. Wherever you find the joint whisper :)
08.05.2020 14:10 # 4
Onur
I strongly recommend wd 40 even the slightest squeak
08.05.2020 14:10 # 5
hasimayaz
DW 40 or philips red
08.05.2020 14:10 # 6
Thank you for the suggestions; it seems to me that I can't do this myself; For this reason, a place recommendation in Ankara that would do this job would be very good. Save it from this malady, I'm not going to freak out ...
08.05.2020 14:10 # 7
I think I will try WD 40; I researched a little bit on the internet, there are two different products; one says general-purpose spray and the other is a multi-purpose rust remover. Which should I buy?
08.05.2020 14:10 # 8
Murat
Both of them will solve your problem, but if you use the general purpose, it does the lubrication. It also protects against long-term rust and dirt.
08.05.2020 14:10 # 9
Thanks for the answer. I think I will get it in a few days; I think of squeezing everywhere I can reach the bottom of the seat after taking it; Does it cause trouble?
Can we also apply this spray to every floor and floor that makes other creaking or clicking, etc.? Does it matter whether it's plastic, metal or wood?
08.05.2020 14:10 # 10
Cagdas
I have the same problem. Excessive creaking noise in the bumps, especially from the driver's seat and door.
Have you tried the "problem man" mentioned? is the sound cut off?
Let me use it accordingly.
08.05.2020 14:10 # 11
Murat
You can use it anywhere. It does not cause any trouble.
08.05.2020 14:10 # 12
sdurmus61
My 407 grandfather's sunrof's on / off button is where the squeak comes from, but it does not happen until it accelerates, it cuts when it accelerates, what can be done in the spongy structure
08.05.2020 14:10 # 13
H-a-d-i
[QUOTE = problem man] I think I will try WD 40; I researched a little bit on the internet, there are two different products; one says general-purpose spray and the other is a multi-purpose rust remover. Which should I buy? [/ QUOTE]
Take the yellow navy box.
08.05.2020 14:10 # 14
I just placed the WD-40 order, I hope I will try it over the weekend.
Now I have listened to all the sounds, something new comes out and obsessed as I listen ... Click and creak is coming from other places in Kasis and pits ... Our work is long ...
08.05.2020 14:10 # 15
vbmaster
I'm glad you got it done, let me know the result from here I wondered if it will pass now :) I will buy 5-6 bottles then I'll eat a market like this :)
08.05.2020 14:10 # 16
I ordered WD-40 general purpose spray; I looked at the evening and cut the bill as WD-40 rust remover on the internet; I sent a message; they had no spray, they were sending the other for him. Where can I find general purpose spray in Ankara?
08.05.2020 14:10 # 17
vbmaster
There are many auto-makers, you can be surprised, for example, you can find your ridicule before you go, there are on the scythians, there is an ostim in the urgency ... and even in a few of the gas stations ...
08.05.2020 14:10 # 18
Cagdas
[QUOTE = problem man] I ordered WD-40 general purpose spray; I looked at the evening and cut the bill as WD-40 rust remover on the internet; I sent a message; they had no spray, they were sending the other for him. Where can I find the general purpose spray in Ankara? [/ QUOTE]
I will try it at the first opportunity I bought from KOÇTAŞ today, will it work?
There are all building markets, koçtaş, bauhaus, praktiker
08.05.2020 14:10 # 19
[QUOTE = problem man] I just joined your friends, I have a problem I hope you can help:
I don't call it piano without sound
08.05.2020 14:10 # 20
[QUOTE = polatkaptan] [QUOTE = problem man] I just joined your friends, I have a problem I hope you can help:
I asked Bauhaus and Koçtaş; there is no general purpose spray to me; They say there is a rust remover. I wonder which one you bought?
Page : / 3
