seat height adjustment
08.05.2020 16:33 # 1
murat deniz
hello friends,
i need your help again for a topic i am curious about .. how is the & nbsp; seat height adjustment for my & nbsp; car model? Under the seat, there is a & nbsp; thin iron pipe & nbsp; I tampered with it but I did not get any results. & nbsp; it says that the iron piece is for seat height adjustment, but couldn't I?
08.05.2020 16:33 # 2
yavuz25
Do I need to have three arms, my brother's back and forth arm, backrest level arm and depth arm?
08.05.2020 16:33 # 3
murat deniz
there is a back and forth lever and backrest level lever yes there is even a backrest level lever handle, but what is the depth handle?
08.05.2020 16:33 # 4
yavuz25
My brother adjusts the height of the seat you are sitting in. So the answer to your question is. "Smile"
08.05.2020 16:33 # 5
murat deniz
Here's how we do it :) There is a handle under the seat, but what is it playing back and forth.
08.05.2020 16:33 # 6
yavuz25
Did you try to go upstairs, my brother
If you have a photo, your arms would be very nice "Smile"
yavuz25 2012-02-01 20:04:05
08.05.2020 16:33 # 7
murat deniz
it doesn't move about anywhere :( may it not be on my model?
08.05.2020 16:33 # 8
yavuz25
can be room. "Smile"
08.05.2020 16:33 # 9
ByHack
In the 307s, the seat of the seat is on the door side, but in the form of a long horizontal arm ...
08.05.2020 16:33 # 10
peugeotefe
When you sit on the left front seat, there is a plastic piece where your 3 fingers will enter, provided that your feet are pressed firmly to the floor, and your right hand is parallel to the right side of the seat, you can adjust it by pulling it up & nbsp;
08.05.2020 16:33 # 11
murat deniz
I'll try the first thing tomorrow morning .. thanks for your help.
08.05.2020 16:33 # 12
aspirinxlarge
Exactly, if you have a sheath or something, it is stuck at the bottom. & Nbsp; It is the same in me, probably in the same place. triangle round mix plastic piece & nbsp;
08.05.2020 16:33 # 13
Kemanyak
There is a round circle-shaped plastic arm, losing itself backwards by taking power from the upstream feet. You will go down :-))) If you are at the bottom, it will rise if you pretend you are a little up.
