Seat belt pulls slowly
08.05.2020 21:28 # 1
BurakGms35
my seat belt is collecting slowly, what should I do is an easy suggestion :)
Thanks in advance ...
08.05.2020 21:28 # 2
BLACK LION
You pull the belt all the way out of the reel and spray the back-sided silicone spray. It will be useful to tighten it a little towards the reel. Pull it out a few times and let it get used to it. You will now see that it has collected quickly.
08.05.2020 21:28 # 3
BurakGms35
thank you so much I will try today
08.05.2020 21:28 # 4
TRK
[QUOTE = BLACK LION] Pull the belt all the way through the reel and squeeze a double-sided silicone spray. It will be useful to tighten it a little towards the reel. Pull it out a few times and let it get used to it. You will now see that it has collected quickly. [/ QUOTE]
I tried with Würt brand silicone spray. But when it comes to an end, it is slow again, so there was no complete solution. The part with the reel needs to be opened.
08.05.2020 21:28 # 5
remove the bakelite on the belt and tighten the silicone spray in such a way
08.05.2020 21:28 # 6
TRK
[QUOTE = sonerkyl] Remove the bakelite on the belt and tighten the silicone spray so that the teacher is inside the mechanism especially [/ QUOTE]
Soner teacher, I looked at youtube and I couldn't find anything. Do you know any assembly-disassembly videos?
If I open it, I can't pull it up now Wacko
