seat belt lamp
08.05.2020 18:55 # 1
xmen
friends, I have a problem that when the seat belt is not attached, the indicator lamp does not have to light up in my car does not light what could be the problem
08.05.2020 18:55 # 2
Alicilik
What is the vehicle, teacher?
08.05.2020 18:55 # 3
xmen
[QUOTE = Buyer] What is the car, teacher? [/ QUOTE]
307 1.6 premium 2006 model
08.05.2020 18:55 # 4
xmen
No one is faced with such a situation, friends
08.05.2020 18:55 # 5
baybaba
It also needs to sound an annoying warning, if not, there is a problem with the connections
08.05.2020 18:55 # 6
mistercasper
In my vehicle, the seat belt warning does not light up, it does not give a broken bulb warning ... My guess is that the owner before me used the xenon headlight and turned on the malfunction lamp. It was closed in the service ... The service warned the warning notices again, but for 70 TL, so I did not open it too, probably yours is also closed from the system ...
08.05.2020 18:55 # 7
xmen
It should be as you said yes. So is the seat belt active when used this way?
08.05.2020 18:55 # 8
mistercasper
Of course you can test it by pulling fast with your hand already active ...
08.05.2020 18:55 # 9
ismailkaya
Check the contours under the seat
08.05.2020 18:55 # 10
xmen
[QUOTE = mistercasper] Of course, you can test the active by pulling fast with your hand ... [/ QUOTE] As far as I know, it does not activate when the seat belt is not worn as far as I know. Are the aerials active when used in this way?
