Seat Belt / Glass?
08.05.2020 18:00 # 1
Hello friends;
As the seat belt enters the pit, there is a wicked noise. I've been hearing for the last 2 times, but I didn't care. I couldn't figure out exactly where it came from, but certainly not from the engine or shock absorbers. I am very sensitive to the sound coming right next to my left ear. What should I do if the source of the problem is from the seat belt equipment? or if it is by Cam ... I would like your help, Ouch
dogan106 2013-10-22 14:37:00
08.05.2020 18:00 # 2
Serkan
I also had a sound at the door Dogan, I did not find the source of the sound for 5 years, it was clicked in me, but this kind of sounds makes people annoyed, it is difficult to find the source.
08.05.2020 18:00 # 3
[QUOTE = Serkan] I also had a sound at the door Dogan, I did not find the source of the sound for 5 years, it was clicked on me, but these kinds of sounds are annoying and difficult to find the source. [/ QUOTE]
Cry
08.05.2020 18:00 # 4
pusutr
When I changed the front shock absorber mount, the sound was cut off.
pusut is 2013-10-22 16:27:59
08.05.2020 18:00 # 5
serkans
my friend check the safety belt I have the same voice in me comes from the seat belt
08.05.2020 18:00 # 6
[QUOTE = pusutr] sound was cut off when I changed the front shock absorber mount.
My ears are definitely sharp, coming from the top of my left ear or from the level of my ears. Big smile
08.05.2020 18:00 # 7
[QUOTE = serkans] my friend check the safety belt I have the same sound on me comes from the seat belt [/ QUOTE]
Help about the solution pls Big smile I do not have a shake. As I can't oil: D
08.05.2020 18:00 # 8
serkans
getting used to the solution :)
08.05.2020 18:00 # 9
muku
The pejoda sound system is so common :) if you listen to loud music, it won't be a problem, otherwise the pejoda will end my voice
08.05.2020 18:00 # 10
[QUOTE = muku] pejoda sound system is so common :) If you listen to loud music there is no problem, otherwise the pejoda will end my voice [/ QUOTE]
It was very good ^^ Clap
