Seat belt and oil lamp in 206+
08.05.2020 16:59 # 1
Kadir
Hello friends. We bought a new 206+ 1.4 HDI & nbsp; urban move vehicle. There are a few details I wonder. There is a seat belt lamp on the instrument panel, but it does not work. & nbsp; In 206+, the user manual says that if the seat belt is not attached when the ignition is turned on, the lamp will light up with an audible warning. & Nbsp; I asked the authorized service but his man did not understand much. it was the envy version. I said let's look at his seat belt lamp, if it burns, the problem is our vehicle. We tried and did not burn it. Then the man said they did not code that feature. Can this feature be activated later?
My second question is about the oil lamp . Shouldn't the oil lamp come on when the ignition is switched on for 206+ diesel vehicles? It's not burning in ours. I know that when we turn on the ignition for the first time, the system should normally turn on the warning lamps to check itself. Abs, airbag, battery, handbrake, stop, particle filter lamp are normally on. We have the old renault 12 oil lamp on it even when we first turn on the ignition :)
I have a question about an exterior temperature gauge urban MOVE, these functions can not have an external temperature we press briefly on the right button of the digital display showing time of wonder manual says to show short-term I did something I've never press? & nbsp; male from vehicles sent to Turkey I think they're trapped in a feature. & nbsp;
08.05.2020 16:59 # 2
Alicilik
Is there a drop shaped plastic piece under the right mirror? if he has it, you can see the temperature. Or is messy business.
a system not activated for turkey on seat belts. There are a lot of features like this, hidden: D guys have even blocked cruise control.
I don't know the oil lamp. Other than engine electricity, the others are not so important. Even if there is a problem with the vehicle (even if the battery is running low), the STOP text warns everything.
08.05.2020 16:59 # 3
Kadir
Yes, there is a drop-shaped plastic piece under the right mirror, but it does not show the temperature by a short press on the button to the right of the digital display. When I press this button only when the radio is on, it switches to display the date when it shows the station frequency.
08.05.2020 16:59 # 4
Alicilik
When you come to the service, they open for 5 minutes.
Is RDS information available?
08.05.2020 16:59 # 5
Kadir
There is a button on the radio but the room is not exiting.
08.05.2020 16:59 # 6
Kadir
[QUOTE = Buyer] Is there a drop shaped plastic piece under the right mirror? if he has it, you can see the temperature. Or is messy business.
I don't know the oil lamp. Other than engine electricity, the others are not so important. Even if there is any problem in the vehicle (even if the battery is running low), the text STOP warns everything. / div>
08.05.2020 16:59 # 7
Alicilik
[QUOTE = Kadir] There is a button on the radio but the room is not exiting. [/ QUOTE]
Go to the service where you bought the car, open rds and degree. They are opening under warranty, do not give money fn
oil lamp believe me I have not caught my attention, I usually look at the light under the fuel needle and start the starter when it goes out.
