Saving Mode
08.05.2020 16:04 # 1
woshborn
Hello friends, I want to be enlightened about something
You know that Peus has Saving mode and it changes between 45 minutes and 5 minutes while this vehicle is not working.
Vehicle 2010 model and the battery saves itself within the time period I mentioned above and the battery is the original factory battery.
08.05.2020 16:04 # 2
The battery has nothing to do with Amps. Something software.
08.05.2020 16:04 # 3
metin
I think it is not in amps, batteries etc, but it is in the saving mode according to the programmed time in the vehicle's brain. If it was a battery related situation, it would not be enough to start the vehicle and stop immediately after you put it in saving mode, since the battery cannot be charged.
08.05.2020 16:04 # 4
woshborn
thank you for your valuable information, so is there a solution for changing this software and setting this option?
08.05.2020 16:04 # 5
As it is said by other friends, this has nothing to do with battery amps;
Recently I Replaced My Vehicle's Battery ... The Old Battery was 60 Amps, The Battery I Have Installed Now is 70 Amps,
After a certain time, it enters the ECO-MOD, which we call Saving Mode.
08.05.2020 16:04 # 6
woshborn
Colonel, there is a solution for this :)
08.05.2020 16:04 # 7
I know that there is no software solution. However, it could be canceled after a detailed operation in the electrical installation. For this, I think it is not worth tampering with the electrical installation.
08.05.2020 16:04 # 8
[QUOTE = Berkay] I know that there is no software solution. However, it could be canceled after a detailed operation in the electrical installation. I think it is not worth tampering with the electrical installation for this. [/ QUOTE]
+100 Thumbs Up
08.05.2020 16:04 # 9
BAHTIYAR
Role of the tape is inserted into the role or a fuse. Even if the vehicle goes to the eco mode, the tape works. It was also in my 307. You also know wrong.
08.05.2020 16:04 # 10
The tape is turned off and eco mode is active, the tape actually plays 2-3 times more than that time, but here it takes eco mode. When it comes to your problem, nothing changes. I have a pearl gold battery in me. 70 or 72 amps.
08.05.2020 16:04 # 11
[QUOTE = BAHTİYAR] Role in the socket of the tape or a fuse is plugged in. If the vehicle goes to eco mode, the tape works like that in my 307. Also, you know wrong. It has a relationship with the amperage or voltage.
Why Didn't It Realize In My Car? The old battery was 60 amps. Now 70 amps enters Eco Mode in the same time period. Göz Kırpma
08.05.2020 16:04 # 12
[QUOTE = AlbaYDemircaN] As it says in other friends, this has nothing to do with battery amps;
Man's battery 70 amp guys Sırıtma
huseyinturk 2011-09-01 02:46:30
08.05.2020 16:04 # 13
ECO-MODE can be canceled with Peugeot Planet 2000 but not recommended. Koliva 2011-09-01 06:33:40
08.05.2020 16:04 # 14
[QUOTE = huseyinturk]
[/ QUOTE] Hüseyin Bomba Vursun You Sırıtma
08.05.2020 16:04 # 15
Anammmm Is 70 Amps. Abovvv regards, Colonel Demircanım.
Shhhh, quiet and silence, gentlemen. Embarrassed
08.05.2020 16:04 # 16
BAHTIYAR
[QUOTE = AlbaYDemircaN] [QUOTE = BAHTİYAR] Role or a fuse is plugged into the tape socket. Even if the car goes to the eco mode, the tape works like that. In my 307, I also know it is wrong. / quote]
Was the old battery weak? My old battery was weak. It passed very quickly. How many times did I try it? Colonel? Sırıtma But as I said, the tape is fixed by attaching an apparatus.
08.05.2020 16:04 # 17
Yucel
[QUOTE = koliva] ECO-MODE can be canceled with Peugeot Planet 2000 but not recommended. [/ QUOTE]
As Koliva wrote, it can be easily canceled with Peugeot planet 2000 in services.
08.05.2020 16:04 # 18
gogly35
I have been receiving a saving mode warning on my trip computer lately without starting the ignition, what could this be the sign?
08.05.2020 16:04 # 19
Serkan
After stopping the vehicle, even if lights, tapes, wipers, etc. are opened and closed, the vehicle switches to saving mode after a certain period of time.
08.05.2020 16:04 # 20
gogly35
I dealt with the license plate lighting then gave the warning .. saving money is good in reverse Smile
Page : / 2
