Sansuman oil
08.05.2020 19:02 # 1
ysndrsn19
Friends, I bought a 2006 model auto lpg 206 mi 67000 km. It is at 112000 km now and I have never seen the transmission oil. Should I have it, if I have it, what should it cost and where should I have it? There are many people who say that they should not be checked. What do you think?
08.05.2020 19:02 # 2
Barut
In automatic vehicles, transmission oil is very important, I think it should change every 50 thousand.
08.05.2020 19:02 # 3
pierson
The masters say that the transmission oil does not change. He doesn't say anything else.
08.05.2020 19:02 # 4
riderzist
[QUOTE = pierson] The masters say the gearbox oil does not change ... it doesn't say anything else ... does anyone know what it really should be? [/ QUOTE]
the manual tools that those masters say do not change it changes in 70 70 thousand or 1 year in 5 years, this oil deteriorates. You start to feel gears in automatic, and it starts to harden manually, since it is time to change. I changed it last month, the manual gears have softened so much that I wish I had changed it long ago ... you will buy mobile gearbox oil recommended by peugeot. used to be a total di. & nbsp;
you don't listen to that master go to pejo citroen particle 206 mobile automatic transmission oil & nbsp;
< / div>
(It takes 2 liters, you can add a little more, you can add 20 g of oil that is not important. It already says 2 liters in your booklet.) & nbsp;
Go to a master, change the transmission oil here. Did something change as soon as possible. Is there a life-long oil, or is it possible that oils with a shelf life of 5 6 years will not deteriorate while working? it is already time to change ..
riderzist 2015-01-28 23:41:28
08.05.2020 19:02 # 5
10URAKAR
Hello there,
I don't know if I have an automatic pugeot 206.
I do not know if the car has also changed the man I bought in 137 000.
The vehicle is 2000 models ... As the other friend says, the masters say it doesn't change, but I read that it always changes.
My auto also sometimes protects the vehicle (in the `` S '' and `` * '' modes) some have written replace oil, but some have said it would be worse if the oil changes ... ???
I didn't know anymore ..
08.05.2020 19:02 # 6
muro_60
new oil is always good transmission takes 2 lt automatic, I do not know how much it takes but change
08.05.2020 19:02 # 7
pierson
Yes guys .. my car is also snow VW sports code is burning.It started to be 100,000 km later ..
