Sancak water leak hk. |
| 08.05.2020 20:25 | # 1 |
307 2006 hdi, I have a problem with water flow. The interior ceiling lamp is missing from the holes there, the drain pipes on the right and left of the saver may be clogged. If there is dirt by pressing air with the compressor, the problem will be solved when you open it. However, I tried it before the air started, by pouring water and quickly draining the water in both the right and left flumes, so there is no problem in that part. What is the problem? Thanks. |
| 08.05.2020 20:25 | # 2 |
sonerkyl |
First of all, welcome to us. the relevant topic will help you. |
| 08.05.2020 20:25 | # 3 |
Thank you for the answer, but my problem is a little different, the saver is running out of water, but the inner ceiling lamp is running through the hole in the hole there, and it may be wrong for me to remove the plastics in the duct and reclaim it again because the water does not come from the edges but the ceiling lamp comes from there. spreading directly and in that way.
| 08.05.2020 20:25 | # 4 |
If the antenna is above the top lamp, it can take water from the antenna. It's in the 206s, but I don't know 307. It is likely to be a water drain channel. Yes, the water you spill may be draining from the drain, but if there is a leg up to the point, it will drop down. |
| 08.05.2020 20:25 | # 5 |
Yesterday I dismantled the front light lamp and opened the floor to the left side of the saver to a certain extent, inspecting it under the groove and checking the front left drain pipe. First of all, I plugged the mouth of the right and left drainpipes to determine where the water flowed, and I poured 1 pet bottle of water into the trough and started to wait the place where the water flowed. As a result, after 2 minutes, I found that the front left side was missing from the silicon, but it was not finished, and there was another leak in the same area, but I could not locate it exactly. There is another drip 2 cm behind the drain hole and this is a more important leak because that part is below the groove that goes directly to the drain. I checked from above, but I could not see any place. Could the water in that part come from the region that originates from silicon?
| 08.05.2020 20:25 | # 6 |
sonerkyl |
[QUOTE = ASIL] Yesterday I removed the front headlamp and opened the floor to the left of the saver a few inches to examine under the groove to check the front left drain pipe. First of all, I plugged the mouth of the right and left drainpipes to determine where the water flowed, and I poured 1 pet bottle of water into the trough and started to wait the place where the water flowed. As a result, after 2 minutes, I found that the front left side was missing from the silicon, but it was not finished, and there was another leak in the same area, but I could not locate it exactly. There is another drip 2 cm behind the drain hole and this is a more important leak because that part is below the groove that goes directly to the drain. I checked from above, but I could not see any place. Could the water in that part come from the region that originates from silicon? [/ QUOTE] It may come from the hole under the plastic piece on the left front, which is likely to come from where you say.
| 08.05.2020 20:25 | # 7 |
Maybe I have to start experimenting with silicon, what kind of silicon should I use for this ...
