Sagon swing
08.05.2020 16:53 # 1
yigiteroglu
Hello friends. I went to the private service because of the labyrinth sound coming from the right ten wheels on the broken road on the vehicle in my signature. Unfortunately the service did everything to get all the money in my pocket. Just as he started to deteriorate, he bent over ... The only correct thing he was saying was that a light-shaped iron piece with a rubber connection on the right side had to change. I did not even say what that piece was, I researched and found that it will swing. Yes, friends, right, ten swings are broken. There is no problem on the smooth road, but the sound is lacquered on the rough road. I plan to travel from Ankara to Alanya on Sunday. Will swing prevent me
08.05.2020 16:53 # 2
hsnsnl
as soon as I know, it only makes lak .. but of course it is necessary to pay attention
08.05.2020 16:53 # 3
sahin-peugeot
Do not set off without changing the swing, you will go a long way, do not endanger both your own and someone else's life, if you are fast, if the part breaks or the ball joint is dislodged, you can lose steering control
08.05.2020 16:53 # 4
yigiteroglu
Thank you very much for your precious explanation.
08.05.2020 16:53 # 5
xpyhre
He probably has an hour of work. It may also depend on the workload of the master. In my case, the rear swing and axle head had changed, it took a maximum of 2 hours.
08.05.2020 16:53 # 6
yigiteroglu
Hello friends, I am in Alanya :) We had a very pleasant journey with my car. Today, I showed the vehicle to a master in Alanya, he took care of me with all his warm bloodshed, he put the swing, and he said the sound was right, he said the right rod, there was a gap, the sound was probably made of it, but even if it was not, the tire had to be replaced and the rot was changed. There is no problem on the straight road, while it is freezing on the bad road, if you need to describe the sound again, it may be a master shock absorber, such as happening in flexing like a full sound, or a chock. There is a year guarantee, when the holiday is over, if you have anything to do, do not think it is important to say that you will get me from Ankara to the area or the most logical in the future. What is the problem? The price is between 60-120 for the depreciation.
08.05.2020 16:53 # 7
yigiteroglu
Tomorrow we will be able to remove the depreciation from the springs and control it
08.05.2020 16:53 # 8
It does not sound like a wedge from a wedge. It sounds like a metal rubbing sound. I recommend you look at the axes.
08.05.2020 16:53 # 9
yigiteroglu
What is the cost of axles
08.05.2020 16:53 # 10
yigiteroglu
Well, if the axles have urgency, can the problem be caused by the ear of the motor?
08.05.2020 16:53 # 11
I think you should have a nice rot-balancer look at the vehicle and test it. It will be healthier.
08.05.2020 16:53 # 12
monur
[QUOTE = yigiteroglu] What is the cost of the axles [/ QUOTE]
hehehe has been dealing for 2 days, it is very expensive, but if anyone can find it, send it to me. & Nbsp;
08.05.2020 16:53 # 13
yigiteroglu
Is it a dangerous situation that will prevent the flock if the axles are broken
08.05.2020 16:53 # 14
monur
[QUOTE = yigiteroglu] Is the dangerous situation that would prevent the flock if the axles are broken [/ QUOTE]
The part that transmits the power from the engine to the wheels is called an axle.
08.05.2020 16:53 # 15
The axle is an important part, if it breaks, it may cause an accident. God forbid. man can understand) There is a place you say. Talk about the problem beautifully. Especially when the car is yawning, say there is a plug sound, quit a test tool.
08.05.2020 16:53 # 16
yigiteroglu
The axles were checked and the solid problem came out on the right swing ten friends. In fact, since the beginning of the mountain, I said ten swing will swing the master swing. So I went to buy the piece, after the master changed, I made a test drive and share the result.
08.05.2020 16:53 # 17
yigiteroglu
Right ten swings changed problem fixed
08.05.2020 16:53 # 18
Get well soon.
08.05.2020 16:53 # 19
yigiteroglu
Thank you, I wish I was in Istanbul.
08.05.2020 16:53 # 20
yigiteroglu
Don't we have a sponsor in Ankara?
Page : / 2
