saej dynamo conjunctor and indicator malfunction signs
08.05.2020 19:21 # 1
swing67
While driving, the speed indicator fell to zero and all the lamps, ABS, airbag, stop, etc. were lit on the display. As a result of all my researches and studies, I found that the charging dynamo produced too much electricity, that is, the conjunctor was faulty. We are in the testing phase right now.
An important point was that the vehicle was not connected to the teck device, so nobody said it was caused by the fault.
08.05.2020 19:21 # 2
Fthz
Get well ... There are those who have the same problem ... Someone I
It is not difficult to find the connector in Istanbul, they wanted 170 mitsubishi brand, the workmanship was 70 TL ... The charge dynamo went through complete maintenance.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=39767&kw=%dearj+dinamosu&pıd=547120&title=breaking-fault-abs-fault-airbag-fault-hatasi#547120
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=39778&title=circuit-elec-defaillant-ile-baslayan-sorun-zincir
08.05.2020 19:21 # 3
erenahmet95
our vehicle had been the same way. But when he changed the connector, he didn't keep the dinoma again and gave the same mistakes again. We bought the original dynamo again. I hope you won't have a problem.
