Rumbling sound from the pads made you tired |
| 08.05.2020 19:46 | # 1 |
| 08.05.2020 19:46 | # 2 |
sonerkyl |
sound thin high pitched voice makes industry pads teacher, but only the brake pressure comes.
| 08.05.2020 19:46 | # 3 |
No, teacher, this sound is not pressed to the brake, but the tingling sound in the bumps ... I changed it with the trw lining pad.
| 08.05.2020 19:46 | # 4 |
sonerkyl |
I understood then there seemed to be a problem with the calipers, it seems to me that there is a problem with the caliper, after the pad change, the sound disappears and continues after a while.
| 08.05.2020 19:46 | # 5 |
If the caliper will explode a little, then we will see the master again.
| 08.05.2020 19:46 | # 6 |
There was a tick in me. Even when entering the pit, there was no sound when the brake was applied to light pressure. Turns out, the Masters who did not install the springs of the pads when changing the pads.
| 08.05.2020 19:46 | # 7 |
the sound is cut off when you wear the original pads
| 08.05.2020 19:46 | # 8 |
I think most of that possibility. I will take the springs anyway. Let's look at the same master.
| 08.05.2020 19:46 | # 9 |
By the way, I had a trw pad installed ... I know it was good pad but ...
| 08.05.2020 19:46 | # 10 |
friends, we put on the original pad, we also changed the discs because it was stripping the pad again, it sounds like a jerk again.
| 08.05.2020 19:46 | # 11 |
[QUOTE = cihan_ch] friends we put on the original pad, we also changed the discs because it was peeling off the pad again, it sounds like a jerk I will be crazy [/ QUOTE] 0532 063 0423 erdinç veteran caucasian auto pendik intermediate opinion helps
