Rumbling sound from the front right
08.05.2020 20:51 # 1
Gurhanm
good morning sentence
I did share it for the torsion in the last position, thank God we got it done right now there is no click on the back, but I bought ultra racing 5cm sports bow and put it on my car while the car was standing still, when I maneuver it, it knocks at the certain maneuver degree in the form of a tough, and it comes out of the right tire. By the way, it is already coming on the broken road. When the vehicle is stationary, I hit the tire with my hand and the sound seems to come from the carrier. Now, where do you think this question might be coming from? If I turn the steering wheel while standing still, why do you think the tough knocking sound might be causing? Thank God, I am waiting for your help.
Gurhanm 2018-04-24 11:44:49
08.05.2020 20:51 # 2
RP393
I also have the same brand 5 cm bow. The sounds started the day I put it on. Just clicking on the left and right turn. The shock absorber is making the tower ball or wedge. Because it's too flat. I have been using it for a long time.
08.05.2020 20:51 # 3
Gurhanm
I bought it with your suggestion, my brother is also satisfied, the handling and comfort is nice, but it did not fall as I want, because the engine is small, is it still going on?
08.05.2020 20:51 # 4
RP393
[QUOTE = Gurhanm] I bought it with your suggestion, my brother, I am glad, the handling and comfort is nice, but it did not fall as I want, because the engine is small, is it still going on you?
Not as much as before. There is little noise when turning right and left only on parquet floor. I guess it only eats from the life of the tower wedges and balls. My 1.6 petrol was fine, 2 fingers between the fender. The lip in the front is rubbing, sometimes I am comfortable outside.
Did you spend 1 pod hose from the top to the springs, right?
RP393 2018-04-24 12:01:18
08.05.2020 20:51 # 5
Gurhanm
I had a brother, I would throw a photo if I was at home, but I thought it was as if the carrier was coming from there, I changed it to the printing pad.
08.05.2020 20:51 # 6
Oguzhan1818
What is the reason why you have a hose run, I think I have a friend
08.05.2020 20:51 # 7
Gurhanm
while passing through the pits to avoid making noise, etc. Hose is inserted in order to prevent the sports broadcast from absorbing the shock absorber layer and making noise, rather it is recommended
08.05.2020 20:51 # 8
Oguzhan1818
Do you have a photo, my brother can you throw it? If you applied it, I wore it 5cm last year.
08.05.2020 20:51 # 9
Gurhanm
I am working right now, when I am available, I will throw how many engines
08.05.2020 20:51 # 10
Oguzhan1818
206 1.6 xt 110mm
08.05.2020 20:51 # 11
Gurhanm
my 1.4 2.5 finger goes in and still falls in front of you 1 1.5 fingers I guess what is my rim tire size what my 195/45/16
08.05.2020 20:51 # 12
Oguzhan1818
195.55.15 I do not want my brother to fall too much.
08.05.2020 20:51 # 13
KILIC
Could they put the springs upside down?
08.05.2020 20:51 # 14
Gurhanm
According to my research I know that there is no reverse of the publication in the 206's.
Brother, there is 1 finger left between the rubber fender, your 5cm can drop a lot in your car.
08.05.2020 20:51 # 15
Oguzhan1818
Can you write your brother number
