Rubbing sound from the front (PROBLEM SOLVED)
08.05.2020 21:25 # 1
307_hdi_XR
Hi friends. It's been a month since I took my Pejo 307 1.4 Hdi XR 2004 model car. I changed the brake pads, it comes again ... The sound comes out parallel to the rotation of the wheel, not according to the engine speed. What could help please. print said it will replace the lining !!!
307_hdi_x is 2020-04-22 12:29:47
08.05.2020 21:25 # 2
307_hdi_XR
CryDeadCryCryCryDead
08.05.2020 21:25 # 3
ismailkaya
If the clutch ball is defective and the noise is interrupted when the clutch is pressed, the clutch ball is coming from the pressure pad.
08.05.2020 21:25 # 4
307_hdi_XR
Mr. Ismail, thank you for what we wrote. I think I will do as you say.
08.05.2020 21:25 # 5
307_hdi_XR
What will happen when I lower the clutch in March?
307_hdi_x is 2020-02-01 00:57:27
08.05.2020 21:25 # 6
307_hdi_XR
Yes, the problem has been solved. The gearbox is not something. The aluminum part that the right axle suspension ball has entered has made a blank. It looks like an oil.
307_hdi_x is 2020-04-22 12:31:20
08.05.2020 21:25 # 7
TRK
[QUOTE = 307_hdi_XR] Hi guys. It's been a month since I took my Pejo 307 1.4 Hdi XR 2004 model car. I changed the brake pads, it comes again ... The sound comes out parallel to the rotation of the wheel, not according to the engine speed. What could help please. print said it will replace the lining !!!
Since 2014, I have the same sound, I mean headlight headlight sound. It was good, teacher, let me change this piece at the first opportunity.
08.05.2020 21:25 # 8
307_hdi_XR
Well TRK my friend, solve this problem, you can't get enough of driving the car ... Big smileSmile
08.05.2020 21:25 # 9
TRK
€ 077;
08.05.2020 21:25 # 10
ismailkaya
The axle center ball had never occurred to me, as you said let me write aside it stems from there
